It is currently Sat Feb 16, 2019 9:45 am
 Post subject: Heads Up & Car Monitor
PostPosted: Fri Jan 13, 2012 11:25 pm
My heads up works fine but I can't get it to move up and down. I've tried moving very slowly but will on move a tiny bit up at the start then doesn't move anymore as I move the adjustment up - any ideas on this? My car monitor also started flashing and going off and back on - I'm assuming a short somewhere in it's wiring - are there any common areas to look at - the three guages over near it are reading unusal also which may be a grounding issue also. Thanks
PostPosted: Sat Jan 14, 2012 3:48 pm
DIC first. A short would likely blow a fuse. You have an intermittent connection. Remove the cluster, disassemble it board by board (carefully) and put it back together. That will probably do it.
While it's out, you can inspect the mechanical cable between the adjust lever and HUD.
PostPosted: Sun Jan 15, 2012 12:37 pm
Year and Trim: '92 Bonneville SSE
the height adjustment in the HUD is a sort of potentiometer. i suppose it either needs replacement or cleaning. junkyards in some places will give the entire control module away at least around here. should just unplug easily (if you remove the wood facing first)
1992 Pontiac Bonneville SSE (3800 Series I, 277K miles and counting! with a horrific knock sadly)
PostPosted: Sun Jan 15, 2012 12:56 pm
That is incorrect. In 92 and 93, it's a mechanical cable. Later years were an electric motor. Go play with yours. You can actually feel it pulling on the HUD when you adjust it. If yours is truly electrical, it was replaced at some time in the past with a HUD from a newer car.
Most Bonnevilles don't have the fake wood trim, either. You should call it the dash trim, or dash bezel.
PostPosted: Sun Jan 15, 2012 5:00 pm
on mine Will ('92 SSE) it has both the woodgrain and the pot (in fact the height switch feels just like the dimmer one.
PostPosted: Sun Jan 15, 2012 5:21 pm
I can guarantee you that the height adjust on your car was originally cable driven. If it's not, someone swapped it at some point as I stated above. I've been into far more of these cars than you, and for many, many years. 92 and 93 were absolutely mechanical in adjustment from the factory.
Pull yours. If you find only wires and not a cable/rod, it's been changed. You might be surprised by what you find. In the meantime, I'm doing my best to make sure the OP gets accurate information to help him.
There are no new unread posts for this topic. Light monitor
ColdScrip
Sun May 24, 2009 12:38 am
ColdScrip View the latest post
There are no new unread posts for this topic. Oil Life Monitor?
LeSabre in Buffalo
Sun Sep 07, 2008 8:06 pm
There are no new unread posts for this topic. How to trick the lamp monitor?
SSEiMan01
Fri Jan 31, 2014 2:13 pm
There are no new unread posts for this topic. P1652 IAC Monitor Disabled by PSP Switch Failed On
anwisdom
Tue Sep 30, 2014 1:40 pm
anwisdom View the latest post
There are no new unread posts for this topic. Low coolant, Lamp Monitor, Brake/tail light warnings
Troxartes
Sat Jun 08, 2013 6:49 pm
Pontiac1 View the latest post
