It is currently Sat Oct 11, 2025 11:42 pm
Post new topic Reply to topic  [ 5 posts ]
 Post subject: Rear coil spring weird!
PostPosted: Tue Jan 15, 2013 1:40 pm
Hey guys, I jacked up the rear end to pull the wheels and check things out to find this on the RR.
The drivers side is nice and straight and seated at the top..what gives??
I can see both shocks leaking pretty bad and the are coming out for replacement; the RR side is tight at the upper mount.
Thanks!
PostPosted: Sun Jan 27, 2013 11:26 pm
Any ideas? Spring seems to be intact, can't find any cracks or breaks and suspension hang is equal on both sides.
Thanks
PostPosted: Mon Jan 28, 2013 2:40 pm
No ideas at all, thats strange....
PostPosted: Mon Jan 28, 2013 9:32 pm
Somebody might have taken it out at some point, and then did not put it back in the same position it was originally in. (Proper procedure; mark the front with sharpie marker before removal, make sure that mark is in front when you put it back.)
Rotational position DOES matter with these things, according to the suspension designers.
Ken_W
PostPosted: Sun Feb 03, 2013 1:53 pm
I checked it out and the end of the lower pigtail on this side is positioned to the rear of the car and the drivers side is positioned to the front, 180 opposite. I will be rotating the passenger side to see if that straightens it out.
Thanks!
There are no new unread posts for this topic. Rear driver coil spring perch rotted; need advice
quicksilver
14
8097
Sun Sep 30, 2018 9:00 pm
Jjohns1110 View the latest post
There are no new unread posts for this topic. Broken coil spring
Merrillspontiac
15
3154
Sat Mar 28, 2009 10:16 pm
Archon View the latest post
There are no new unread posts for this topic. coil spring question
BestBonnieYet
Fri Dec 03, 2010 5:46 pm
There are no new unread posts for this topic. Coil Spring OEM number??
loudog1972
Mon Oct 27, 2014 3:50 pm
2003 SSEi View the latest post
There are no new unread posts for this topic. Front coil spring replacement
Jason H.
Sat Dec 18, 2021 3:10 pm
Jason H. View the latest post
Users browsing this forum: No registered users and 18 guests
