It is currently Fri Sep 12, 2025 4:10 pm
PostPosted: Tue Dec 06, 2016 6:04 pm
Year and Trim: 02 SLE
Is there a way to make them come up on the DIC?
If I need a scanner to do it is there a low cost good option out there now days to buy?
PostPosted: Tue Dec 06, 2016 6:20 pm
hi, you can get a decent tool for about 80 bucks at walmart - roadi nsg 100 is what I have and it does more than just pull codes.... there are cheaper ones out there but this one is well worth the money
PostPosted: Tue Dec 06, 2016 9:05 pm
Sadly, no way to read them in the DIC on our cars.
PostPosted: Wed Dec 07, 2016 1:36 pm
Bummer. My Dodge pickup will show me the codes in the odo display after 3 key cycles.
The light wasn't on this morning, but a co-worker loaned me his scanner so I can check it out.
PostPosted: Thu Dec 08, 2016 6:01 pm
Year and Trim: 01 SLE
Picked one up for $60 @ Advanced Auto that does the job.
01 Bonneville SLE
PostPosted: Fri Dec 09, 2016 1:30 pm
OBD bluetooth scanners that interface with your phone can be had pretty cheap.
PostPosted: Fri Dec 09, 2016 11:56 pm
OBD2 compliant cars need a scan tool to display codes while OBD1 cars could display codes by flashing the CEL when jumping the OBD1 port. A cheap code reader can be purchased for 30-50 bucks or a cheap bluetooth scanner from Ebay will get the job done with the programs available for your phone.
There are no new unread posts for this topic. Shopping for OBDII Scan Tool/ Software
flatlander745
Tue Sep 18, 2012 2:18 pm
There are no new unread posts for this topic. Inexpensive way to scan for ABS codes?
Oldman
Wed Apr 06, 2016 11:29 pm
Oldman View the latest post
There are no new unread posts for this topic. Software to read all codes
johnrich
Tue Mar 04, 2014 11:28 pm
knott View the latest post
There are no new unread posts for this topic. P0404, p0442, p1404 codes, rough idle, And trouble starting
comatoast
Mon May 28, 2012 6:25 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Codes Codes and more Codes ABS/Brake/TRAC
bc21
11
6904
Wed Feb 29, 2012 12:23 am
Archon View the latest post
Users browsing this forum: No registered users and 18 guests
