It is currently Sat Oct 11, 2025 8:48 pm
PostPosted: Sun Jul 21, 2013 3:14 pm
Year and Trim: 2004 se
I have a 2004 Pontiac Bonneville SE. The airbag warning came on and stays on. I flashes 7 times at start-up then stays on until I turn of the car. I had the entire airbag module replaced an that did not solve the problem. My mechanic says it might be the clock spring assembly. Where would I find a clock spring?
PostPosted: Sun Jul 21, 2013 11:58 pm
Were the codes pulled for the airbag system to identify the problem before the module was replaced? If not, go to the dealer or a well equipped shop that has a scanner that can read those codes before replacing any other parts.
PostPosted: Mon Jul 22, 2013 5:47 am
The code said the airbag system was the problem.
PostPosted: Mon Jul 22, 2013 11:20 am
Can you get the actual code?
There are no new unread posts for this topic. Turn off airbag warning light after front seat swap?
erekstad
Sun May 23, 2010 11:40 am
Merrillspontiac View the latest post
There are no new unread posts for this topic. Battery light comes on and stays on.
kaotikd
Sun Nov 07, 2010 8:18 am
kaotikd View the latest post
There are no new unread posts for this topic. Battery light stays on
Kevin Amstutz1
Sun Nov 06, 2016 7:01 am
Kevin Amstutz1 View the latest post
There are no new unread posts for this topic. Airbag light...
BoneZ
Sun Jun 22, 2008 12:20 am
BoneZ View the latest post
There are no new unread posts for this topic. "Anti-Lock" warning triggered by bumps, stays on for trip
Dean
Fri Aug 16, 2013 11:07 am
Dean View the latest post
Users browsing this forum: No registered users and 22 guests
