It is currently Tue Sep 30, 2025 9:20 pm
 Post subject: Master cylinder change
PostPosted: Mon Jan 19, 2009 3:35 pm
Year and Trim: 1995 White Bonneville SE
Ive recently had to add a little brake fluid to my master cylinder, which was about 3/4 full.
Today I noticed that master cylinder has been leaking(now I know why I have to add!!)
How hard is it to change out, and what parts store should I get a new/reman one from??
188340 Miles as of 06/07/10, still running.........
LIM/UIM Work done 4/23/07 at 145000 miles...
PostPosted: Mon Jan 19, 2009 3:39 pm
They are not too hard to change, just remember to bench bleed it. 2 bolts and the lines to remove and then bleed the entire system when done . Bleed starting with the wheel farthest from the master cylinder and so on. Usually it will go: rear passenger, rear driver, front passenger, front driver.
As for where to get one it just depends on what you want to spend and if you can wait for shipping. There is Rockauto.com and GMpartsdirect.com.
PostPosted: Tue Jan 20, 2009 5:13 pm
Year and Trim: 1993 Bonneville SE, restoration finished
yeah, bench bleed the master cyl before installing it. And the best way thereafter is to bleed all 4 wheels as stated above, until clean fluid without air bubbles comes out.
Or in a pinch, you don't need to bleed the wheel cyls, but this is at your own risk, although I have done it dozens of times:
Bench bleed the master cyl, bolt it to the booster. Have a helper slowly push the brake pedal to the floor and hold it there. Have something to catch the fluid, and make sure they go slow or you'll have a gusher all over you and the car. Then, with the pedal held to the floor, hook up and tighten the lines. Any air at the top of the lines should be sucked back into the master cyl and bubble harmlessly up when you slowly release the pedal. No need to bleed if all worked well. If the pedal is funny after a few pumps, then you have to bleed at each wheel.
1993 SE with SLE appearance package. Factory stock except for steering wheel buttons, AM/FM/CD from a '93SSEi and chrome wheels.
1999 Olds Eighty-Eight LS Anniversary Edition, my daily driver.
2004 Chrysler Minivan, wife's daily driver.
There are no new unread posts for this topic. Brake Master Cylinder on a 94 SE
spoiledred94
Fri Jul 10, 2009 3:00 pm
There are no new unread posts for this topic. Master Cylinder help needed
ChilinMichael
11
2140
Tue Jul 31, 2018 7:51 am
wpbrink View the latest post
There are no new unread posts for this topic. Master Cylinder question
mythicSSEi
Sun Nov 02, 2008 11:45 pm
willwren View the latest post
There are no new unread posts for this topic. Master cylinder. .. 99' Bonneville
wpbrink
Tue Jul 31, 2018 2:25 pm
95naSTA View the latest post
There are no new unread posts for this topic. Rock Auto Master Cylinder: Which One?
hailwood1965
Thu Dec 22, 2016 10:16 pm
MKMike View the latest post
Users browsing this forum: No registered users and 20 guests
