It is currently Tue Sep 30, 2025 9:19 pm
 Post subject: Air shock pressure?
PostPosted: Mon Mar 16, 2009 6:04 pm
Year and Trim: 1998 bonneville SSEi
hey guys i had to convert my ELC to a manual fill set up for the time being, my question, how much pressure are the shocks capable of holding?
 Post subject: Re: Air shock pressure?
PostPosted: Mon Mar 16, 2009 6:42 pm
They're CAPABLE of 70psi. Many of us trick the system at the track to run full height, and the compressor is capable of that.
If you're using stock struts and the pump and manually filling, I doubt you'll ever be anywhere close to 50psi. It'll likely be quite a bit lower for a level ride.
PostPosted: Mon Mar 16, 2009 9:37 pm
ok i just wanted to know in case i want to really pump them up. is it recomeneded to bring it to 70psi or is that max, should i try to stay under that?
PostPosted: Tue Mar 17, 2009 12:34 am
Year and Trim: 99 SSEi
I think 20 - 25 lbs will make the car level.
2006 Chevy Monte Carlo SS
There are no new unread posts for this topic. P0108 Manifold Absolute Pressure/Barometric Pressure Circuit
laimisl
33
7879
Sat Mar 12, 2016 9:59 am
MKMike View the latest post
There are no new unread posts for this topic. setting up a gas shock system
spoiledred94
Sat Oct 23, 2010 11:59 pm
There are no new unread posts for this topic. Rear shock and alignment
krummelt1
Mon Oct 18, 2010 9:29 pm
There are no new unread posts for this topic. Shock questions KYB excel-G
Pair of SSEI
Sun Dec 03, 2017 9:04 pm
Pair of SSEI View the latest post
There are no new unread posts for this topic. How is Camber affected by shock placement?
StraTact
Sat Jun 17, 2017 8:29 pm
95naSTA View the latest post
Users browsing this forum: No registered users and 17 guests
