It is currently Tue Apr 16, 2024 12:02 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Mon Mar 09, 2009 9:52 am
trf, on yours the shock is not really a critical component. The best option for yours is this:
willwren wrote:
No, there are not.
Our mounts are quite different, and typically aren't a problem other than the front trans mount at about 100k, and the torque-axis mount a little bit later in life. You can try what I did though (keep in mind this is my 4th prototype, but works very well and is adjustable):
(remember, this is for 92-99, the front trans mount)
Update, several days later. Round 3 is done.
The ammo. Leftover endlink bushing from the 'rear' universal kit, endlink washer, allthread, lockwashers, standard nuts, and nylock nuts:
This is where it's going. We're looking down from the top of the radiator. Rear of the car to the top of the pic, front of the car to the bottom of the pic. That black trans mount is going to get drilled from bottom to top:
Remember that long drill bit in the first pic? It cost me $11. 3/8" diameter. I drilled through (be VERY careful doing this, you have to hit a very small pocket between the mount and trans, and if you miss, you won't be able to get the back side nuts on). I had to use my cordless drill to 'screw' the threaded rod in and out because of the grip of the rubber in the mount:
Here's the other end. I hit the zone. It's still going to be tough to get the washers and nuts on:
Closer view:
Now let's modify that polyurethane bushing. We're taking the little ring off the top so that it sits flush on the bottom face of the mount. the top in this pic (as viewed) will be against the mount:
Here's the bushing with the 'crown' shaved off:
Fitting the length to cut the rod. Make sure you leave enough on the other end for a washer, lock washer, and 2 nuts:
Cut to length:
Daddy got a head start, and had to recruit Katie, still in PJ's, for the extra set of hands. She handles the impact wrench like a pro:
Flat washer, lock washer, standard nut, and Nylock nut on the back side:
Endlink polyurethane bushing, endlink washer, lockwasher, standard nut, and nylock nut on the front (bottom) side:
Tightened to compression+. So it's just starting to swell.
This mount should naturally damp vibration almost as well as stock. It will use the OEM rubber wedge for compression (letting off the gas), and the poly bushing for extension or tension (rolling on the loud pedal).
Road test coming soon.
_______________________________________________
Guess what? I BROKE that one. Granted, I'm putting a bit more torque through this thing than most people, but I improved it.
________________________________________________
Hold the presses. I broke it today.
Not sure if it was grade 2 or grade 5. Snapped in half (tension, not shear) leaving the parky lot for lunch a little while ago.
It snapped in half inside the rubber block, sounded like a rifle shot hitting the front of the trans. It was the INSIDE half that broke off and came out. The lower half including bushing are still stuck in the rubber.
I think it may be time to increase the allthread grade and possibly the diameter also.
Grade 2 is 74,000psi tensile strength.
Grade 5 is 120,000psi tensile strength.
Grade 8 is 150,000psi tensile strength.
Bare minimum, under hard accelleration, It took 37 TONS per square inch to snap it. Possibly up to 60 tons depending on grade. Time to go shopping again.
It would have been worse if the other end had broken and shout out. Trans cooler lines are directly in the path. Just imagine how much energy it had coming out. And the velocity it would have been travelling at.
I'll be cross-drilling and safety-wiring the next version. Tethers if it makes more sense.
Edit: Found the nylock on top is mashed. Going to look at the car. Pics soon. Everyone in the car FELT the broken piece hit the trans. Not feeling the mount flex, but the actual shot from the broken piece.
Edit again:
Went out and found the washer. 316 Stainless. Just like the threaded rod. Stronger than Grade 5 by a small margin. Upgrade that to 120,000psi or 60 tons per square inch. This being 3/8 or .375, it's taken somewhere around 20 tons of force to rip it apart in tension.
I'll work something up for you guys shortly. I got a 3/8" LONG drill bit at Home Depot to allow me to drill it in place without removing the mount. You have to be VERY careful to drill straight. It's best to have a spotter above AND below. I suggest putting a white mark on the top of the mount. Even white tape. In a straight line along the drill path. Then paint the drill bit white so the top spotter can see both the tape line and the white bit to keep you straight.
When you get through the lower face of the mount and the rubber, STOP and insert the threaded rod, stand back, and make sure you've come into it straight. If not, use the drill bit as a mill and 'work it' over to where you need it before drilling through the rear (trans side).
The best washers to use are the ones that come with the universal endlink kit, which you need anyway to get an endlink bushing for the project. I used a standard Stainless nut on each side, backed up with a nylock to keep it from backing out. Like I said though, I'll work something up in cad for you guys.
That shows the tape reference on the top for the right angle. Be aware it's VERY critical you hit the EXACT spot on the back side, and it's very difficult to place a nut and washer back there. I welded a box-end wrench to that nut, and left it in there to 'back up' the nut when I'm adjusting tension on the bottom side. The wrench is captured between the mount and trans to prevent it from rotating naturally (then I cut the open-end of the wrench off). The wrench stays long-term on mine.
In the pic above, the gray washers and nuts are standard. I chose 316 stainless. The gold washer comes with the endlink kits (Energy Suspension poly endlink kits, or buy the universal bushing/washer set). The blue nut is a nylock for safety to make sure it doesn't work loose.
To adjust it, I back the nylock off until its flats are aligned with the nut between, then use a deepwell socket on BOTH, to either add or remove tension. Then I tighten the nylock back against the other nut when I'm done.
Let me be clear......it's very easy to MISS the little pocket in there that you need to hit, so use the spotters as I detailed in MY PREVIOUS POST ABOVE.
Keep in mind, get the strongest grade or ASTM hardened allthread to start with. I've also attached a wrench to the back side that prevents that rear nut from moving so it only takes one person to adjust the tension on the mount.
The beauty of the design, if done properly, is that it's adjustable. I can tighten it up for the track. I now have the rear nut 'retained' so I only have to adjust from underneath.
(Edit, we should probably get this back on topic out of respect for the topic author. If you have any questions, just start another topic in P/B)
PostPosted: Mon Mar 09, 2009 11:45 am
Quote:
I think she reacts a bit quicker to the throttle now. That's probably just in my head though, I doubt I'd feel that difference.
It's not in your head. You should be able to feel the difference when accelerating hard or at the track.
Use the end link like Bill showed above and put it under the bolt head under the frame on the '00+ cars. My grade 5 bolt is holding up fine after 4 WCBF's. :wink:
PostPosted: Mon Mar 09, 2009 5:45 pm
So far, no luck finding a grade 8 rod. And I hadn't noticed any bolts long enough. Checked Napa, Advance, Lowes, and Ace Hardware. I have a couple more places I can look though.
So far, I'm loving it though!
PostPosted: Mon Mar 09, 2009 7:31 pm
Booze, look for a Fastenal, or other place that specializes in nuts and bolts. They're more likely to have an oddball bolt like that.
PostPosted: Mon Mar 09, 2009 8:04 pm
Year and Trim: 2002 SSEI
ALL STOCK (FOR noW)
humm.. i wonder if thats whats wrong with my mount it moves a nice amount and it's as tight as it can get humm this has me thinking about my hard shifts now
PostPosted: Mon Mar 09, 2009 11:01 pm
I got mine at fleet farm, but that was grade 5. but i would think ACE would have it. they have every bolt and nut out there!
PostPosted: Mon Mar 09, 2009 11:40 pm
Never seen a Fastenal, Ed. There is a store called York Bolt that I'm gonna try near campus but I got there too late tonight.
PostPosted: Tue Mar 10, 2009 7:19 pm
Oh, we have one near us, and they stock our bolt bin that we have here at home.
http://www.fastenal.com/
PostPosted: Tue Mar 10, 2009 8:19 pm
York bolt had what I wanted. :banana:
PostPosted: Tue Mar 10, 2009 8:23 pm
Sweet!!!
PostPosted: Tue Mar 10, 2009 8:32 pm
Year and Trim: 2001 GMC Yukon XL
nice work killin the mount booze :P
glad you got it fixed for good tho.
-Matt
PostPosted: Thu Mar 12, 2009 8:25 pm
seems like a few of us are having this same problem.viewtopic.php?f=18&t=9497
I just did mine but am upgrading to a block of rubber from a semi trailer (which they use to dampen vibrations) This way there is no risk of the vibration caused by the hockey pucks harming anything weak on the car. Especially under the dash.
FWI, converted low beam bulbs into high beam bulbs, 20% tint all around, MSD wires, NDK TR55 plugs, auxiliary line in, scan gauge, custom FloPro/MagnaFlow Cat back exhaust
2002 Bonneville SE
PostPosted: Thu Mar 12, 2009 8:48 pm
I used a rubber mount used to dampen vibrations on machinery at my dad's work also.. the vibration comes not from the pucks, but from the bolt or nut touching the bottom of your frame.
PostPosted: Thu Mar 12, 2009 9:21 pm
oh ok, so i should get a couple rubber washers for under the frame then?
2002 Bonneville SE
PostPosted: Thu Mar 12, 2009 9:26 pm
yup. that or an old endlink or something to put between the bolt and the frame, the metal on metal will cause vibration.
PostPosted: Thu Mar 12, 2009 9:37 pm
i;m guessing the bushing, not the endlink??
PostPosted: Thu Mar 12, 2009 9:43 pm
i guess the "bushing" part form an endlink kit.. obviously not the metal rod :booty:
PostPosted: Thu Mar 12, 2009 10:32 pm
sorry not to familiar with all parts of a car. What does this part look like?
2002 Bonneville SE
the red things at the top of the page that bill posted
PostPosted: Thu Mar 12, 2009 10:34 pm
so basically another small block of rubber?
2002 Bonneville SE
There are no new unread posts for this topic. solid mount
2631
Thu Nov 20, 2008 6:38 pm
There are no new unread posts for this topic. Tested out my new suction cup mount.
SSEiMan01
21
2267
Mon Feb 27, 2012 11:10 pm
There are no new unread posts for this topic. hockey puck mount
redeyesbonnie
Mon Mar 16, 2009 10:40 pm
Night Crawler View the latest post
There are no new unread posts for this topic. How To: Replace Front Motor Mount 02 Bonneville
ironoxide
Tue Dec 06, 2011 9:03 pm
mrwildroot View the latest post
