It is currently Mon Feb 18, 2019 12:31 pm
Post new topic Reply to topic  [ 182 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
Part it or fix it?
Part it out 30%  30%  [ 21 ]
Fix it up and sell it 70%  70%  [ 48 ]
Total votes : 69
 Post subject: Re: project 40th
PostPosted: Wed Apr 22, 2009 6:56 pm
Exhaust leak fixed! http://www.pontiacbonnevilleclub.com/fo ... 71#p119671
Still not getting power. Have swapped the MAF, IAC, and TPS. My next guess is fuel filter/pump. I am yet to put my fuel pressure gauge on the rail, just been so preoccupied with the exhaust leak.
-Andrew-
PostPosted: Wed Apr 22, 2009 7:06 pm
Change the fuel filter, and do the seafoam trick. Actually, reverse that. Do Seafoam then Fuel filter.
PostPosted: Fri May 01, 2009 12:53 pm
Year and Trim: 1993 SSEi, Red Bonnechetta
2003 GMC Envoy SLT
It's May 1st, Andrew. Any updates??
Adam
1993 SSEi "Red Bonnechetta" COTM July 2014
2003 GMC Envoy SLT
PostPosted: Mon May 04, 2009 11:43 am
The project is in someone else's hands at this point. I brought the car to my dad's this weekend to see if he had any ideas with it. He ended up falling in love with it and bought it from me. As you know he is a GM mechanic and should be able to figure out the problem better than me. He is curious to see whats causing it. When he drove it he said it sounds like the engine isn't getting enough air. He thinks maybe the timing chain is stretched. We shall see, but at least its out of my hands, LOL! I'll let everyone know what he figures out is wrong with it. I really didn't even get to do everything I wanted to do to it, oh well. Many of you know that he already owns a DCM 97 SSEi, but recently he let my brother borrow the car because he needed a 4-dr car with his kid. That borrowing session turned into a kind of ownership so my dad basically gave the car to my brother. He wants another 97 SSEi and because this one was a 40th, it makes it all the cooler. BTW, I sold the car for $2000, about $1000 under book, but about $1300 in profit.
-Andrew-
PostPosted: Mon May 04, 2009 12:24 pm
Did you take it out on our trailer?
PostPosted: Mon May 04, 2009 12:35 pm
Yup
-Andrew-
PostPosted: Mon May 04, 2009 12:49 pm
Ka-ching, Haro makes bank!
PostPosted: Mon May 04, 2009 1:17 pm
Do you think I could buy the Grizz off my son for $2000 ? :bhuh:
PostPosted: Wed May 06, 2009 3:45 pm
Year and Trim: 1998 Volkswagen Beetle
1983 Pontiac Bonneville
You did wonderful work, Haro. Could you keep us updated if your dad figures out what's wrong with it? I'm curious now.
Formerly BonnieBrougham
Just cause you got the monkey off your back doesn't mean the circus has left town.--George Carlin (R.I.P.)
In Storage: 1983 Pontiac Bonneville Brougham, 87,000 miles, 305 v8 4bbl
PostPosted: Wed May 06, 2009 7:13 pm
Year and Trim: ____
I'm also very curious! :happy1:
John
PostPosted: Wed Jun 10, 2009 10:27 pm
Bump. Dad has been working on figuring out the problem for weeks now. He finally decided it was that the timing chain jump causing the timing to retard. He removed the front cover and found the chain and tensioner to be in good condition. He then discovered that the harmonic balancer pulley was installed incorrectly. Whoever put the new crankshaft position sensor in before I bought the car, installed it wrong. They didn't use the key and just rammed the pulley on. He said it was about 30° off. So when the CPS thought the pulley was at TDC, it was not even close... which causes major runability issues. He is working on putting things back together with a new chain and tensioner and all new gaskets. Should be running really good after its done. I'm glad he figured it out, because I surely never would have.
-Andrew-
PostPosted: Wed Jun 10, 2009 10:28 pm
That's good to hear!!
PostPosted: Wed Jun 10, 2009 11:36 pm
Great that he discovered this.
Exactly what happens when people who probably shouldn't work on vehicles do. Nothing wrong with learning by doing, but wow... do your homework first!
PostPosted: Thu Jun 11, 2009 7:24 pm
Year and Trim: 1994 K1500 Silverado
i just came across this post again, and wow haro, that car..... came a LONG way lol. did i see duct tape on the trunk lid though? GAH, i hate getting that stuff off.
It's been a very long time, but, I am still around!
PostPosted: Thu Jun 11, 2009 11:13 pm
Ya the duct tape held the trunk lid shut before the latch was installed. The tape residue comes off easily with lacquer thinner.
-Andrew-
PostPosted: Fri Jun 12, 2009 9:59 am
oh, guess that would make sense.... thx!
PostPosted: Wed Jun 17, 2009 11:54 am
He got it back together a few days ago. It runs like a top!
-Andrew-
PostPosted: Wed Jun 17, 2009 1:25 pm
Cool beans... Glad to hear it.. :twisted:
PostPosted: Wed Jun 17, 2009 1:59 pm
good to hear!
PostPosted: Wed Jun 17, 2009 2:23 pm
well... now he's got one heck of a good looking AND running car!
There are no new unread posts for this topic. 40th in NJ
ohenry5
Sat May 30, 2009 1:25 pm
ohenry5 View the latest post
There are no new unread posts for this topic. The Silver 97 SSEi 40th
Blown93SSEi
18
2084
Sat Oct 11, 2008 2:31 pm
Blown93SSEi View the latest post
There are no new unread posts for this topic. 1997 SLE 40th Anniversary 2.0
94SilverSSEi
Wed Sep 11, 2013 7:20 pm
Boreas View the latest post
There are no new unread posts for this topic. Goodbye Bonneville 40th, hello Acura
ohenry5
Wed Nov 28, 2012 12:22 am
Hotwheels View the latest post
There are no new unread posts for this topic. 1997 40th Anniversary Bonneville
GotBonneBWitMe
14
1831
Wed Sep 25, 2013 10:15 pm
PilotScott View the latest post
Users browsing this forum: Exabot [Bot] and 4 guests
