It is currently Mon May 20, 2019 1:31 am
Post new topic Reply to topic  [ 182 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
Part it or fix it?
Part it out 30%  30%  [ 21 ]
Fix it up and sell it 70%  70%  [ 48 ]
Total votes : 69
 Post subject: Re: project 40th
PostPosted: Fri Apr 03, 2009 10:43 pm
Year and Trim: Sapphire -1999 SSEi Metallic Navy Blue
I swear,you could polish a .05 turd and turn it for 100.00 :hail:
fuelforthesoul1999 wrote:
Sapphire, of course, god that's the automobile equivalent of Halle Berry, you just want her.......
Quote:
Without question, the greatest invention in the history of mankind is beer. Oh, I grant you the wheel was also a fine invention, but the wheel does not go nearly as well with BBQ!!
PostPosted: Fri Apr 03, 2009 11:00 pm
Year and Trim: 2000 ssei
harofreak00 wrote:
After that, only a few issues remain: Mounting the new truck latch and replacing the grumbling motor mount.
sounds like somebody's got truck on the brain :laughing3: this is an awesome turn around to watch it must be immensely satisfying at the end of the day to know that car looks like that because of your hard work.
2000 ssei white debadged, autozone solid front mount, NGK tr55 plugs, Napa Beldin wires, MSD Coils, drilled slotted rotors, monroe max air rear shocks, 18" KMC Hot wheels redline w/ 235/50/18 bfg G-force tires, pioneer DEH-P580mp deck, Infinity Ref 6.5s and 5.25s, Kappa 6x9's on crossfire amp, kappa 12 on kenwood amp, and cleared headlights.
Gumball wrote:
my pockets dont sag and are still kinda tight.
PostPosted: Fri Apr 03, 2009 11:09 pm
That's some mighty fine work there, Andrew! Looking VERY nice! Bet you're glad now that you didn't go ahead and part it out ;)
PostPosted: Fri Apr 03, 2009 11:28 pm
Year and Trim: 1997 SSE 40th Anniversary
Andrew, you are the man! Nice work. Gosh I loveee the 40th in that color!!! (I'm not biased at all, lol)
1997 SSE 40th Aniv. Dark Cherry Met., 35% tint all around, Chrome T-Stars, stock everything else
PostPosted: Sat Apr 04, 2009 9:27 am
Looking good for sure! The Porter Cable buffer will do an excellent job for you, but be warned. You will very likely end up addicted to what it can do. Even a very light polish will make a huge difference in what the car looks like.
If you are going for perfection, be prepared to spend about 12 hours on the exterior alone. A quick and simple single stage polish would probably take about 3 - 4 hours but will still leave the paint looking absolutely amazing.
Do you know yet what you are going to be using for polish and pads yet?
PostPosted: Sun Apr 05, 2009 5:04 pm
Year and Trim: 1995 SE
Man, that is looking fantastic! Excellent work!
"GM cars run bad longer than most cars run at all"
(yes, I know, it's a crappy photoshop)
'95 Bonneville SE -- mostly stock
2008 Chevy HHR LT
'97 Grand Prix SE
'93 Buick Roadmaster
PostPosted: Mon Apr 06, 2009 12:17 am
Wow, great work. Looks like new!
-Joshua-
PostPosted: Mon Apr 13, 2009 6:58 pm
Year and Trim: ____
Looking utterly fantastic.
Quick question Andrew..
Do you, have you, or are you going to follow up the magic eraser cleanup with a high quality conditioner like lexol? They look fantastic, but it would be pretty sad to see any cracking start from lack of conditioning.
John
PostPosted: Mon Apr 13, 2009 7:56 pm
PSST, I have Lexol. :wink:
PostPosted: Mon Apr 13, 2009 8:43 pm
I have Megs leather conditioner, already applied it.
-Andrew-
PostPosted: Thu Apr 16, 2009 6:34 pm
Did this today: viewtopic.php?f=19&t=11154&p=118216#p118216
Quote:
Well I tinkered on the car a lot today. I got the mount replaced quite easily, I'm glad I didn't drive to Ed's to use the lift, it would have just made things harder LOL.
The front mount was definately shot, but it wasn't causing the grinding. I took it for a test drive immediately after the swap and it was exactly the same. I was pretty sure its not the rear trans mount, so I didn't even mess with it.
I took another look at the TAM mount and decided to take it off to have a better look. It came out pretty easily and I noticed that the metal "tube" was amost completely seperated from the rubber. Looking at how this mount is designed to work, I figured the way it was failing shouldn't be causing the grinding. The engine is pulling down on the mount. However, when the engine is accelerating, the engine rocks back and the TAM actually rubs against the metal engine bracket. I REALLY want to narrow this down, but I don't wanna be tossing money on this car like its nothing. Rockauto wants $41 for the TAM, reasonable. Right?
After getting the mount fixed, I took it for a longer test drive than normal. I got it up to temp for the first time. I pulled into the driveway at home and noticed there was a coolant leak. After the thermostat opened it caused a leak high up on the side of the radiator (the plastic part). I put a couple layers of JB Weld on it, hopefully that holds, I don't feel like getting a new radiator, I just sold my parts car one...ugh.
The car still isn't running 100%. It seems like the MAF is bad, because I can unplug the connector and the idle doesn't change. I swapped in 2 other known good MAF's and it doesn't change either. Maybe I should try some new plugs, who knows how old they are. The wires look new... there is even new dielectric grease on the coils!
I was at the point today where I just want to sell the car, I'm sick of working on it. Gotta keep plugging on... can't give up.
-Andrew-
PostPosted: Thu Apr 16, 2009 6:56 pm
Hang in there, Andrew. You`ll work through this... you always do :wink:
We`ve come to know the top quality work you do!
PostPosted: Tue Apr 21, 2009 3:53 pm
Replaced the TAM today. The grinding is completely gone.
After I fixed the mount, some more problems came into view. The engine still isn't running right. It doesn't sound like a miss, it just doesn't have any power. I swapped out the spark plugs and wires. Didn't change.
-Andrew-
PostPosted: Tue Apr 21, 2009 3:59 pm
Year and Trim: 1999 SLE
Just my .02. When I got rid of my Malibu, it had less power than when new and it had been throwing Catalytic codes. General consenus was a plugged cat. never fixed it, just got rid of it. Just didnt have any oooomph anymore
Glenn
1999 SLE 70k Stock for now
PostPosted: Tue Apr 21, 2009 4:01 pm
Good idea... I'll look into that.
-Andrew-
PostPosted: Tue Apr 21, 2009 4:03 pm
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
2013 Audi A4 6MT
Keep plugging away, Andrew! You've come this way, it would suck if you gave up now...
http://www.youtube.com/watch?v=VZ2HcRl4wSk
PostPosted: Tue Apr 21, 2009 4:54 pm
Year and Trim: 2008 Cadillac STS
go, go, go
Steve
Was - 1998 SSEi - 128,000 mi. ---- SOLD----
Was - 2003 Cadillac DeVille DTS - 91,000 mi. ----SOLD----
Is - 2008 Cadillac STS AWD Luxury, Black/Black.
2008 Ford Fusion SEL, - Midnight blue - Black leather int.
2005 Buick Lacrosse CXL, Silver - Black leather Int.
PostPosted: Tue Apr 21, 2009 5:38 pm
I pulled the exhaust off and took it for a drive (loud!). Still not getting the power it should.
The cat looked fine.
-Andrew-
PostPosted: Tue Apr 21, 2009 5:45 pm
2013 Audi A4 6MT
Uhh, this has probably already been discussed... But have you changed your O2 sensor out recently? It looks like it's been running pretty dang lean... Check fuel pressure? I know my car ran pretty bad with a bad fuel filter...
PostPosted: Wed Apr 22, 2009 3:33 pm
Rats, sorry the cat wasnt it. OTOH, I'm glad it wasnt it. They wanted 250 bux to change mine lol.
Glenn
There are no new unread posts for this topic. 40th in NJ
ohenry5
Sat May 30, 2009 1:25 pm
ohenry5 View the latest post
There are no new unread posts for this topic. The Silver 97 SSEi 40th
Blown93SSEi
18
2132
Sat Oct 11, 2008 2:31 pm
Blown93SSEi View the latest post
There are no new unread posts for this topic. 1997 SLE 40th Anniversary 2.0
94SilverSSEi
Wed Sep 11, 2013 7:20 pm
Boreas View the latest post
There are no new unread posts for this topic. Goodbye Bonneville 40th, hello Acura
ohenry5
Wed Nov 28, 2012 12:22 am
Hotwheels View the latest post
There are no new unread posts for this topic. 1997 40th Anniversary Bonneville
GotBonneBWitMe
14
1892
Wed Sep 25, 2013 10:15 pm
PilotScott View the latest post
