It is currently Sat Feb 16, 2019 9:16 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Fri Apr 10, 2015 10:27 pm
Year and Trim: 2002 Galaxy Silver SSEi
:banana: Finally done with Intense stage 1 performance kit
Tyler
2002 Galaxy Silver SSEi "Silver Shadow" 181, xxx miles- DD, tinted taillights, 10000k HID low beams, GXP strut brace, carbon fiber overlays, GXP door bezels and vents and Aeroforce Interceptor Gauge, cleared corners, drilled and slotted rotors, painted calipers, Intense Stage 1 Performance package, smoked door reflectors.
2001 Galaxy Silver SE 119, xxx miles- RIP
2007 White G6 Economy 96, xxx miles- Wife's car, carbon fiber inserts, tinted windows.
PostPosted: Thu May 21, 2015 9:16 pm
While out today my car stalled and dies under acceleration from a stop light. Figuring it was the fuel filter I bought another and installed it in the lot, still same problem, will start and within two to five seconds it dies while idling. Figured it might be the fuel pump so I pressed on the bypass on the fuel rail and had pressure there, let it all out and then tried to start the car again and still didn't start, pressed again and had pressure again so that rules out the pump. Unplugged to MAF and still the same. Eventually had it towed to y house and have no idea where to go from there. I have a mechanic buddy coming over in the morning with his fancy scanner to see if he CA help me figure it out. Has anyone been through this?
Tyler
PostPosted: Fri May 22, 2015 6:33 am
Year and Trim: 2001 SSEI/2007 TBSS/2004 CTS-V
When my converter clogged on my 98' it acted similar to how you describe it. Un-bolt the O2 sensor a give it a try.
"Big 3", Tint
PostPosted: Fri May 22, 2015 8:09 am
Year and Trim: 2004 GXP
Same thing happened on my late 90's blazer. Only problem was I was in the UP at the time and there were no stores around to pick up the right tools... I took a hatchet to the converter and had a loud trip back to lower Michigan but it drove fine once it was opened up! :btruestory:
2004 Bonneville GXP Crimson Tintcoat- Casual fuel gauge | Brake Performance drilled/slotted rotors front and rear| Retrofit Morimoto mini H1 | clear corners | disabled DRL | 3000K HID fogs | 5% tint | K&N | Yakima rack with fairing, bike rails and kayak rack | Intermittent radio display
1995 Bonneville SSE Deep Amethyst Pearl- SSEI tails | 5% tint | 3 12jlw3v2 in custom enclosure -Gone
1991 Bonneville LE Blue- Alloy spokes -Deceased(deer)
PostPosted: Fri May 22, 2015 10:23 pm
Had my mechanic buddy come by and he told me that there is not enough pressure so it's my pump going out. I found one and will be ordering next Thursday.
Tyler
PostPosted: Sat May 30, 2015 9:22 pm
Got the fuel pump in was a pretty easy fix. Now I need to save some change and repair my rear shocks and headliner and sunroof.
Tyler
There are no new unread posts for this topic. "Sylvia" My Silver Screamer
SSEiFreak
Mon Apr 15, 2013 9:32 pm
SSEiFreak View the latest post
There are no new unread posts for this topic. "The Crow" and "Nevermore", A Trip Down Memory Lane
TrueWildMan
Sun May 25, 2008 4:58 am
TrueWildMan View the latest post
There are no new unread posts for this topic. Silver Shadow wrecked!
Bugsi
29
2624
Wed Nov 11, 2015 1:33 am
BonneMe View the latest post
There are no new unread posts for this topic. Silver Shadow, my 97SE
Bugsi
Wed Jul 22, 2015 12:14 am
Hotwheels View the latest post
There are no new unread posts for this topic. "The Murdersofa" - 2000 LeSabre Limited
Pilot of the Murdersofa
Tue Dec 16, 2014 11:41 pm
