It is currently Sun Feb 17, 2019 7:02 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
PostPosted: Fri Mar 07, 2014 3:50 pm
Year and Trim: 2004 SLE
I'd love to see some pics of your ride on 20s if you got 'em (and what tire size your using as well)
I've seen so many new model cars coming from the factory with 20s that the size thing is growing on me a bit...and the selection of wheels in the aftermarket is pretty vast as well (yes, I'm still looking at gold accent wheels) ;)
2004 Bonneville SLE "Bonnie the Ghosthawk" or the 4dr Firebird...Gone but not forgotten
The Blog, http://www.tobthebat.wordpress.com
Luna LeMans on Smashwords
https://www.smashwords.com/books/view/870754
Luna LeMans in Amazon paperback
https://www.amazon.com/dp/1983273589
PostPosted: Fri Mar 07, 2014 3:57 pm
Moderator
Moderator
Year and Trim: 09 G8 GT
Paging Eric Yonkers!
PostPosted: Fri Mar 07, 2014 6:50 pm
20" are the absolute perfect wheels for these cars in my opinion. There are good and bad wheels depending on the style, but I love 20" on them.
PostPosted: Fri Mar 07, 2014 10:15 pm
I have to admit those 20in Snowflake wheels on the Trans Am at the car show are still working on my head. I'll never pony up $3K for those but I'd love to find something close.
PostPosted: Sat Mar 08, 2014 1:56 pm
Year and Trim: '02 SSEi
Depending on certain factors, 20s can end up being about the same price as 18s as well. I like 20s on 00+ and the selection is very impressive. Not to mention I can always use more room for my brakes.
PostPosted: Sat Mar 08, 2014 2:27 pm
Ghosthawk, what size are the wheels you have currently?
PostPosted: Sat Mar 08, 2014 2:35 pm
Picture if my 20's in my sig. Running factory Camaro tires...245/45's.
Eric
A few mods..
PostPosted: Sat Mar 08, 2014 11:18 pm
Currently running 18x8.5 +35, 235/50 tires but swapping to 245/45s next week...trying a touch more clearance to stop the inner fender rubbing.
Those 20s look boss, Yonkers!
PostPosted: Sat Mar 08, 2014 11:32 pm
Where are you rubbing with 235/50s? Thats stock size for a gxp. Also pretty narrow for an 8.5" wheel.
Im shopping in the 20X8.5-9.0 range with 32-38mm offsets. I just played with my wheel rite tool today and the width and offset you have are pretty ideal. Im looking to run 255/35-20 which has a ~10 tread width and a 27" diameter.
PostPosted: Sun Mar 09, 2014 3:25 pm
Moderator
Moderator
My GXP with the stock wheel and tire combo managed to rub the inner fender at full lock. :dontknow:
PostPosted: Sun Mar 09, 2014 3:57 pm
I have rubbing marks from my stock bent 5s on factory spec tires....
PostPosted: Sun Mar 09, 2014 5:43 pm
There is a welt on the inner fender panel on the passenger side and when I turn right at slow speeds it rubs, especially under braking. The 235/50-18s are just slightly taller than the stock 235/55-17s on the sawblade wheels.
Yes, the sidewalls are bowed out slightly, another reason I think the new 245/45s will work better.
PostPosted: Sun Mar 09, 2014 11:36 pm
You really think ~.2" diameter difference is going to do the trick? The added width might screw with you. There are folks running wider tires than that, so Ill bet youll be fine.
I have wheels and tires picked out but Im still not sure if I really want to run that small of a sidewall.
PostPosted: Mon Mar 10, 2014 12:21 am
I had 245/45-18s on my GP and was pretty happy with them...hope they work as well this time. Dont know how Yonkers is getting by with those 245/45-20s...yikes those are big.
PostPosted: Mon Mar 10, 2014 6:09 am
Those are quite large, but he has a lot less offset, so the tires poke out just a tiny bit, presumably leaving more room behind them.
I had 245/45-18 on my 92 Bonneville. I had to roll my rear fenders and I had some rubbing up front. It was definatwly worth it for the look and handling.
PostPosted: Mon Mar 10, 2014 10:52 am
I think I found the wheels I want.
Lowered on these TSW Nurburgrings in 19/20 inch variety? Calling out Booze for photoshop request.
PostPosted: Mon Mar 10, 2014 10:58 am
Moderator
Moderator
I was really close to getting TSW Nurburgrings in 18x8 to put on the G8... going with the lightweight route. Tomorrow, I'm putting a deposit down on something else though :-$
PostPosted: Mon Mar 10, 2014 11:07 am
I've been eyeballing those. Great looking wheels.
I also really like the enkei raijin in 18x9 I think. If I went the 20" route there a pot less options that I like, but tires are actually cheaper than the 18s.
PostPosted: Mon Mar 10, 2014 1:53 pm
I'm seeing the opposite on the G8. Tire prices go WAY up from 19" to 20". Granted, I'm shopping WIDE tires...
PostPosted: Mon Mar 10, 2014 2:56 pm
245/45s are on and even though a bit shorter and leaving a slight wheelwell gap, I still like the look and the rubbing appears to be gone :)
Unfortunately, now the vibration issue is back and tomorrow I'll have to pull wheels and make sure my centric rings werent lost.
Can nothing ever be easy with this car?
There are no new unread posts for this topic. My New 22 inch Wheels On My Bonneville
Da713Bonneville
26
10213
Sun Mar 15, 2009 5:23 pm
There are no new unread posts for this topic. The $2,500 GXP, running again!
crash93ssei
77
6558
Thu Aug 02, 2012 11:36 pm
There are no new unread posts for this topic. Different Wheels for my GXP
1tinindian
Thu Apr 16, 2015 12:54 am
There are no new unread posts for this topic. New GP wheels
haro1225
12
1300
Sat Sep 29, 2012 2:29 pm
Hotwheels View the latest post
There are no new unread posts for this topic. 92 SE with 96 GP wheels
rtabish
11
1870
Tue Nov 01, 2011 8:48 am
Boss455 View the latest post
