It is currently Tue Feb 19, 2019 7:49 pm
Post new topic Reply to topic  [ 106 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: 95 PAU Project
PostPosted: Mon Dec 24, 2012 12:15 pm
Year and Trim: 1995 Park Avenue Ultra
I should be getting the hood, trunk and fenders here soon. Hopefully that helps alot with how the car looks. I figured someone would catch that, but the magnet wasnt in that pic. I had it out to clean the pan and I forgot to put it in for that pic. But its in and hopefully doing a better job than before.
2002 Dodge Intrepid "Superbee"
PostPosted: Tue Dec 25, 2012 1:43 am
Im just posting this up because my buddy wanted to know what I have
....and what everything means for good measure. Took me a good hour and a half to decode and put it into a decent Word doc.
1995 Buick Park Avenue Ultra RPO List
VIN # 1G4CU5214SH606244
AK5: RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS
AQ7: SEAT FRT SPLIT, 3 PASS, 6 WAY ADJ, RECL
A43: MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER
BMD: PLT R PLANT CODE FLINT, MI, USA
B36: COVERING FLOOR MAT, LUGG COMPT
CF5: ROOF SUN, GLASS, SLIDING, ELEC
CJ2: HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
DA0: ARM REST FRT SEAT, STORAGE
DD0: MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED, LT SENSITIVE
DD7: MIRROR I/S R/V LT SENSITIVE, COMPASS
D85: STRIPE BODY SIDE LOWER ACCENT
D89: PAINT SPECIAL DÉCOR
FE9: CERTIFICATION EMISSION, FEDERAL
F41: SUSPENSION SYSTEM FRT, RR, FIRM RIDE, HANDLING
F79: RATIO TRANSAXLE FINAL DRIVE 2.97
IC2: TRIM INTERIOR DESIGN (C2)
JM4: BRAKE SYSTEM PWR, FRT DISC, RR DRUM, CAST IRON, ANTILOCK, FRT &RR WHL
KA1: HEATER SEAT, FRT
K68: GENERATOR 105 AMP
L67: ENGINE GAS, 6 CYL, 3.8L, MFI, V6, SUPERCHARGED
MX0: MERCHANDISED TRANS AUTO PROVISIONS, O/D
M13: TRANSMISSION AUTO 4 SPD, HMD, 4T60-E, ELECTRONIC
NF2: EMISSION SYSTEM FEDERAL, TIER 1
NP5: STEERING WHEEL LEATHER WRAPPED
NW9: TRACTION CONTROL ELECTRONIC
PY0: WHEEL 16 X 6.5, ALUMINUM
QPE: TIRE ALL P215/60R16/N BL R/PE ST TL AL2
UA1: BATTERY HIGH CAPACITY, WET
UB3: CLUSTER INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UJ2: INDICATOR ENGINE OIL LIFE
UK3: CONTROL STEERING WHEEL, ACCESSORY
UL0: RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, AUTO TONE, CLOCK, ETR
UV5: DISPLAY SERVICE REMINDER
UW6: SPEAKER SYSTEM 6, CUSTOM
U41: INDICATOR LOW FUEL
U75: ANTENNA POWER, RADIO
VH9: ENVELOPE OWNER INFO MAN
VK3: LICENSE PLATE FRONT FRT MOUNTING PKG
VM3: LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH
V73: VEHICLE STATEMENT USA/CANADA
Y56: MERCHANDISED PKG GRAN TOURING
03L: SECONDARY COLOR EXTERIOR, MARBLEHEAD GRAY MET (96)
1SE: PACKAGE OPTION 05
1SZ: DISCOUNT OPTION PACKAGE
14A: STRIPE COLOR ACCENT, LT GRAY (96)
14I: INTERIOR TRIM GRAY
142: TRIM COMBINATION LEATHER, GRAY (2) (97).
6KK: COMPONENT FRT LH COMPUTER SEL SUSP (6KK)
7KK: COMPONENT FRT RH COMPUTER SEL SUSP (7KK)
77U: PRIMARY COLOR EXTERIOR, DK CHERRY MET (02)
8YT: COMPONENT RR LH COMPUTER SEL SUSP (8YT)
9YT: COMPONENT RR RH COMPUTER SEL SUSP (9YT)
PostPosted: Tue Dec 25, 2012 8:39 pm
That car does have keyless right? Most of the time they will have AU0 when they have keyless, but sometimes it can be part of a package and I see you have a 1SE, should be a loaded park ave...
PostPosted: Tue Dec 25, 2012 10:26 pm
I didn't see this until now... I wired in sequential tails on my 85 Trans-Am. I had to replace the outer bulb socket to a dual filament socket so that it would function as a running light and a turn signal/brake light. Wiring in the STS was a pain!! I only did it because I got a great deal on a custom made STS module on another forum. To my knowledge he doesn't make them anymore. But there are other kits.
But I agree, wiring in a larger bulb socket to where the 194 is now would be risky business IMO.
92 Bonneville SSE | L67/4T60E | 72K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule
92 Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Summer Daily Driver and Future Turbo Racekar
03 Park Avenue Ultra | L67/4T65E-HD | 188K | White Diamond Metallic w/Shale & Cashmere Int. | Rust Free Southern Sourced Daily Driver
99 Tahoe LT | L31/4L65E | 237k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig and Portable Concert Hall
04 Cadillac SLS | LD8/4T80E | 186k mi | Red Jewel Tintcoat w/Shale & Grey Int.
09 Malibu LT | LE5/4T45E | 205K mi | Seafoam w/Blk Int.
13 Explorer XLT | 3.5/6F55 | 141k mi | Kodiak Brown w/Blk Int.
James May wrote:
Hello.
PostPosted: Wed Dec 26, 2012 1:04 am
Yep, it has keyless. Funny thing is I busted the first remote trying to take it apart to clean it and I didnt get another until just this week. I think I have every option except a CD player...but I fixed that and grabbed one out of a 99 Limited. Im still learning what some of these codes mean. Thanks for the input!
PostPosted: Wed Dec 26, 2012 1:07 am
Yeah after I looked into it I decided against it. It would be cool, but I dont want to risk these tails. Up here, 1G Parks, especially Ultras, are very hard to find. I've only found two so far and both are base. One just so happens to be the same color as mine with mint panels. It will be donating to my cause soon enough, haha.
PostPosted: Wed Dec 26, 2012 11:09 am
I like the progress you have been making too! :) Every day that I got into my 94 LeSabre to go somewhere I asked myself why my Grandma didn't buy a 94 PAU instead... :roll:
James May wrote:
Hello.
PostPosted: Wed Dec 26, 2012 1:16 pm
Year and Trim: 2002 Now DOA and rear ended like a pig on a spit
Looks great. I had a 92 Ultra back in the mid-late 90's. Great car, loads of power and super comfy. I replaced the trans at 140K, and sold the car shortly after. My wife still talks about that one....
Buy the best and you'll only cry once... Or so my therapist tells me....
PostPosted: Wed Dec 26, 2012 8:58 pm
The old H Body 87-99 and the Old C body 85-96 were awesome cars and built tuff as nails... They were a completely different in the way they rode and handled compared to anything else.. Its was one of the platforms they really got right the first time... Just look how many are still on the road after 20 years... lol
PostPosted: Wed Dec 26, 2012 9:13 pm
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
It's just too bad the rust is eating so many of them.
PAU is a close runner up to the SSEi. Those first gens are my favorite.
Great looking car and good job on the "restoration." Hopefully the tranny just holds together for a while yet now.
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
nos4blood70 wrote:
Literally, cars are drugs.
PostPosted: Thu Dec 27, 2012 2:12 pm
gearhead291 wrote:
looks good squilly. lol have to get some pics of the cars together at dans meet.
I didnt even see your post, lol. Yeah, it'll be our own little H/C meet at an LH meet. However, I dont think I'll be modding this car to the extent of Bertha at other meets. Im sure you remember spring '11. Nightmare.
PostPosted: Thu Dec 27, 2012 2:16 pm
Yeah, thats what makes me paranoid about driving it right now. Honestly I want a 1G Ultra as a summer DD. I dont know whether I want to make this one that and pick up a true beater or keep this a beater and pick up a 96 with OBDII, a 65HD and S2 L67. But for right now she's been getting baths every 2 days or so. And Im hoping that trans does hold out, I've been babying the hell out of it.
PostPosted: Thu Dec 27, 2012 2:51 pm
Year and Trim: 1995 bonnie SE
Lol itll be a meet at a meet. And noo we wont be doing that lol. More time for relaxing and not constantly on the car.
PostPosted: Sun Feb 17, 2013 11:28 pm
So I guess I'll go ahead and update this. Well the tranny went out in spectacular fashion about 40 miles from my house. Apparently the diff somehow split wide open. So yet again the car sits. I knew the trans had an issue, But I wasnt expecting it to physically grenade and leech 7 quarts of fluid everywhere. What adds insult to injury is that while I was at work, my buddy and my father were loading the car on a dolly and I guess somehow the radiator decided to follow in the tranny's footsteps and blew the coolant level sensor straight out and most of my coolant gushed out. So on top of a new tranny, i now need to spend another 150 on a radiator. Honestly, this thing is going to sit....for awhile. Im now forced to drive my Dodge again everyday, but it being winter and no hope avoided the roads now, I see no rush in getting the Buick going anytime soon. It will sit until I regain my cool.
Here's half of the mess the night it went.
PostPosted: Mon Feb 18, 2013 9:21 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
It'll buff out...
What kind of noises was it making, or was it a no-warning 'gotcha!'?
Runs:
Doesn't run:
PostPosted: Mon Feb 18, 2013 10:31 am
Looks like classic differential pin failure.
PostPosted: Mon Feb 18, 2013 10:11 pm
I am sorry to hear about the failure... If the trans is still okish, you could dig up a 3.33 GX3 Diff and the structurally improved diff cover( I think most 95's had this to begin with )
as for the radiator, do your searching... I know you can do better than 150...
PostPosted: Fri Feb 22, 2013 8:26 pm
I finally got up under it to take a pic. Not a pretty sight thats for sure.
The underside was all nice and dry and spotless. Looks like I have some cleaning up to do this spring.
PostPosted: Fri Feb 22, 2013 8:29 pm
Eh, It sounds like the roller clutch and sprag is on its way out so I'm going to drop another trans in it. However it looks like its going to be a slightly more daunting task than when I dropped a new tranny in my Intrepid, not only because of the work but I guess I'll have issues getting one to work?
PostPosted: Fri Feb 22, 2013 8:30 pm
It'll buff out...
No warning, no hint. Just boom.
There are no new unread posts for this topic. My 04 SLE Project
Mach 10
Sun Jul 26, 2009 11:23 am
crazyjoe View the latest post
There are no new unread posts for this topic. New guy, new project!
Rlugo87
Sat Jul 08, 2017 5:26 pm
jonnevilleSSEi View the latest post
There are no new unread posts for this topic. project Bonneville's
olblueeyesbonne
Sun Nov 01, 2009 11:52 pm
olblueeyesbonne View the latest post
There are no new unread posts for this topic. My latest project...
Black Pearl
Wed Nov 02, 2011 3:47 pm
Black Pearl View the latest post
There are no new unread posts for this topic. Project: Oldsmobille 88 LS
[ Go to pageGo to page: 1, 2, 3, 4, 5 ]
tytotheler92
91
6467
Fri Mar 06, 2015 2:51 am
tytotheler92 View the latest post
