It is currently Tue Apr 16, 2024 1:34 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: picture
PostPosted: Wed Apr 18, 2012 4:21 pm
Year and Trim: 2001 white se
 Post subject: Re: picture
PostPosted: Wed Apr 18, 2012 5:27 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Nice car. So who are ya? Where ya from? What does your father do work? etc....that makes for a better intro :wink:
Welcome btw!
PostPosted: Wed Apr 18, 2012 5:57 pm
Welcome! Looks nice! It's the better white (Ivory) and it's an 01... I like it. :)
88 Cutlass Ciera Brougham International | 120k mi | White w/ Dk Claret Int. | Roller to be S2 L67/4T65E-HD | 1 of ~5100 3.8 FE3 Int'l series
05 Acura RL | 155K mi | Carbon Grey Pearl w/Ebony Int. | The Super-Hooptie Daily
James May wrote:
Hello.
PostPosted: Wed Apr 18, 2012 6:37 pm
My name is Ryan, I live in Chattanooga TN.
currently a student at UTC
Im a car lover, and I take pride in learning everything about the cars that I own.
Ive always read about these engines, but Ive never drove one or owned one so Im excited to get my hands on it.
PostPosted: Wed Apr 18, 2012 6:50 pm
89 SkiDoo
Do a search for the maintenance list and also check out these links...
http://www.pontiacbonnevilleclub.com/fo ... =53&t=3591
http://www.pontiacbonnevilleclub.com/fo ... =53&t=1061
http://www.pontiacbonnevilleclub.com/fo ... 18&t=25362
PostPosted: Wed Apr 18, 2012 7:12 pm
Quote:
1987-2005 Bonneville / Buick 3800 Maintenance List
Run Seafoam, Chevron Techron or Gumout Regane through gasoline every 5,000 miles.
Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease or Amsoil Grease recommended)
Air Filter Every 15k (Amsoil EaA, Purolator PureONE)
PCV Valve Every 30k
MAF Sensor Element Cleaning/TB Cleaning Every 50k viewtopic.php?f=48&t=1661
Fuel Filter Every 15-25k (Purolator, AC Delco, WIX) viewtopic.php?f=45&t=23215
Spark Plugs Every 30-50k (NGK TR55, AC Delco 41-101 or Autolite 605) (Never Bosch)
Ignition Wires Every 30-50k (Napa Belden, AC Delco, Autolite Pro, NGK) (Never Taylor or Bosch)
Oil & Filter Every 5-6k or Every 6 months (Valvoline SYNPower, Pennzoil Platinum, or Amsoil )(Mobil1, Purolator PureONE, Amsoil EaO, K&N or WIX) (Never Fram) viewtopic.php?f=45&t=214
*Conventional Oil Every 3k/3 months(API SM/SN rating) (WIX (Napa), Delco or Purolator filter)
Tires: Check Inflation Pressure & Visually Inspect Monthly Rotate Every 6-8,000 Miles
Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) viewtopic.php?f=45&t=10193
Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Mixes-With-Any Coolant Only) (Never Dexcool)
Oxygen Sensor Every 80-100k (30k for non-heated) (AC Delco or Denso) (Absolutely never Bosch) viewtopic.php?f=48&t=794
Accessory Belt Inspect every 15k, replace every 100k, or as needed
Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only) viewtopic.php?f=45&t=13626
Evap Core Cleaning Whenever Needed (Note: 99 and older only) viewtopic.php?f=45&t=2432
Brake Fluid Flush 3yr/50k
Power Steering Fluid Replacement/Flush Every 100k or 5 years
*Special Considerations*
All Series II/III 3800's RPO's: L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
Lower Intake Manifold Gasket Replacement, every 80-100k (ignorance of this can allow coolant to enter your engine oil, this happening can cause irreversible lower engine damage, requiring replacement of subject engine)
Series II, Naturally Aspirated, RPO:L36:
Upper Intake Manifold Plenum Replacement, Every 80-100k (ignorance of this can allow coolant to enter your intake manifold, possible damage to occur can be hydrolock, irreversible damage to emissions devices, misfires, etc. Most times, engine replacement is required if ignored long enough.) viewtopic.php?f=53&t=1061
Series I, II, III RPO Code L67 & L32:
Change Supercharger Oil; Every 30-50k. (Intense Racing or GM Dealer) viewtopic.php?f=56&t=1690
Supercharger Belt; Inspect Every 15k, Replace Every 100k or as needed.
3/2/12 by 00Beast
:beerchug:
James May wrote:
Hello.
PostPosted: Wed Apr 18, 2012 8:31 pm
The guy i got it from has all the records of past maintenance done on the car. We are taking it to our family friend mechanic on friday to get the once over.
PostPosted: Wed Apr 18, 2012 9:37 pm
Good idea on the look over. Providing they don't charge ya hand and foot.
Otherwise, that's a very clean SE you got there. We need more pictures though. :P
"Penelope" - 2003 SLE - 247k Miles
"Sydney" - 2000 Honda S2000 - 98k miles
PostPosted: Wed Apr 18, 2012 10:15 pm
PostPosted: Wed Apr 18, 2012 10:16 pm
Moderator
Moderator
Year and Trim: 09 G8 GT
Moved to Your Ride :)
PostPosted: Wed Apr 18, 2012 10:19 pm
We got a bench seat! That's awesome! That thing is really exceptionally clean.
PostPosted: Wed Apr 18, 2012 10:22 pm
Bench seat or no, I like it!
James May wrote:
Hello.
PostPosted: Wed Apr 18, 2012 11:24 pm
Year and Trim: 1996 SSEi
Ooo, bench seat 2k+. WANT!
I'm backkkkkkkkkkkkkkkkk!
PostPosted: Thu Apr 19, 2012 8:37 am
Year and Trim: 1999 Pontiac Grand Am SE
Ryan theres only 1 reason you want a bench seat and that's cause of Alexis :btruestory:
1999 Grand Am SE (AKA Brandy) 2.4L I4 Mods: Cold Air Intake, 2 Sony 12", 2000w Crunch Amp, Pioneer Head Unit, debadged, tinted tails, 180 stat
TIRE SHINEEEE!!!!!!!!!!!!!!!!!!!!!!!
PostPosted: Thu Apr 19, 2012 8:38 am
#-o
I've always said...Real talent can do it with buckets and a floor console. :-# :-$
James May wrote:
Hello.
PostPosted: Thu Apr 19, 2012 9:40 am
If I remember correctly my grand am back seats are a quarter the size of the limos
PostPosted: Thu Apr 19, 2012 10:21 am
:btruestory:
James May wrote:
Hello.
PostPosted: Thu Apr 19, 2012 10:23 am
Leather cleans easy carpet stains lol
PostPosted: Thu Apr 19, 2012 4:09 pm
Im gunna hafta break her in this weekend :beerchug:
im gunna take my girl on a ride up the mountain when the car gets here on sunday.
PostPosted: Thu Apr 19, 2012 8:30 pm
Year and Trim: '99 Montana
'92 Trofeo
Don't do anything I wouldn't do!... Oh wait....
Um,
did you know the air gets thinner when your in the mountains? :btruestory:
There are no new unread posts for this topic. One picture...just one!
ChilinMichael
16
1518
Thu Feb 09, 2012 9:50 pm
DJC906 View the latest post
Thu Aug 28, 2008 8:24 pm
There are no new unread posts for this topic. Picture time
haro1225
Sat Sep 01, 2012 11:05 pm
Sadden View the latest post
There are no new unread posts for this topic. Had the day off so it was picture time
haro1225
Sun Jan 08, 2012 7:40 pm
2002BonnevilleSE View the latest post
haro1225
Thu Nov 03, 2011 10:32 am
Spitzkindl View the latest post
cron
