It is currently Wed Jun 03, 2020 4:05 pm
Post new topic Reply to topic  [ 390 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20
PostPosted: Fri May 15, 2020 9:03 am
I can't wait to see it when it is all done again. Just looking at your sig photo makes me happy haha
PostPosted: Sat May 16, 2020 10:18 am
Thanks. I can't wait either. I miss having it look that good and can't believe it was last painted just over a decade ago.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Sun May 24, 2020 10:24 pm
I pulled the fenders to re-do the mating surfaces to the bumper. The hang up here was that the E39 sections make a lip on mating area and the fender needs up be built up slightly to hide it. Before I just built up the outer quarter inch or so (to clear the lip) with kitty hair and that's the only thing the bumper was mating against. That bothered me and I wanted to make sure the entire surface was uniform this time around. I decided to use Evercoat Polyflex here after roughing the area up with 40 grit. The idea is that having a flexible friendly filler at the mating surface will fare better. The passenger side is roughed out pretty good but I still need to finish up the drivers.
I also took a look at the bumper to see if it's really a thermoset polyurethane. I was sure the fenders were do to the yellow color but I have suspicions about the bumper since it's dark in color. The ID has "PU" circled which stands for polyurethane and likely thermoset apparently but the more common IDs are "PUR" or "RIM". I set the plastic welder to 'PUR' and it starts the melt the plastic but doesn't seem like it'll weld, so the melting point is polyurethane at least. I'll have to read more..
05 Suzuki DRZ400S
PostPosted: Tue May 26, 2020 4:14 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
It's possible that it is a TPU as well.
But with some older parts the material code wasn't required so it's possible the PU marking isn't a material code, maybe a generic plastic code. I'll see what the bumper on my 93 looks like, I know it's not the same plastic as the fenders, I was able to plastic weld the rear bumper on my 93. It was definitely a glass filled material, which is going to make it very difficult to weld. My initial thought is that it's a glass filled TPU, but it could also be mold/trim/year specific and the plastic changed once or more over the years.
PostPosted: Tue May 26, 2020 9:48 pm
According to this site, your 93 has TPE. I'd be curious to see what marking your bumper has.
https://www.polyvance.com/bumperid.php
A 96-99 SE rear bumper I have has 'PUR' marked on it, which matches that site at least. What's strange is the p/n 25644216 doesn't match any 96-99 bumper though. At least I potentially have something to compare with?
When I went to melt my 95's front bumper in a hidden spot at low heat, it did melt but also kind of sizzled as if it was a thermoset. I think I need to do it again to see if it discolors. I also did a sand test to see if it smears (thermoplastic) or powders (thermoset) but it wasn't very conclusive.
Some good news is the driver side fender is more or less ready to be primed. I finished the bottom, touched up the headlight molding hook area with kitty hair, knocked the vertical area down past primer, swiped the whole vertical area with Evercoat lightweight, hit it with the pneumatic straight line then long blocked it. I left some material on the vertical bumper mating surface to fine-tune when it's mounted back up. The passenger side is basically ready for the light weight swipe but I ran out of time.
05 Suzuki DRZ400S
PostPosted: Thu May 28, 2020 10:55 am
Year and Trim: 2003 SSEi
:hail: I look forward to seeing some paint on this.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Fri May 29, 2020 9:55 pm
Me too!
I noticed an asymmetry in thickness on the passenger side fender so I ground down the vertical area near the wheel wheel and built it up to match the finished driver's side. Then I repeated the process I did on the driver's fender. I left both areas below where the headlight molding hooks in a little rough just so it can be fine tuned when I re-do the bumper and match it.
So this means the fenders are like 95% finished. :bwoohoo:
05 Suzuki DRZ400S
PostPosted: Sun May 31, 2020 12:59 am
So a little more testing and I determined that the front bumper is most definitely thermoset.. There's a float test where if it's a thermoplastic, it'll float, and if not, it's likely a thermoset plastic. It sunk. I also held the plastic welder iron on a hidden lip of the bumper to see if it would sizzle and discolor, which it did. That means it's most definitely a thermoset. I compared it to a mounting tab from the thermoset 96-99 bumper. The textures are definitely different when sanded but react the same when heated.
Now.. With that figured out. I tried to get clear polyurethane rod (designated for thermoset plastic repair) to adhere to the 96-99 tab with no luck. I modulated the temperature as directed to ensure I didn't melt the base material or overheat the rod. I was sure I had this dialed in. I tried to get it do stick to the 95 bumper 3x increasing the coarseness every time but I was able to pull the new material off every time.
So, I'm back to thinking of using a urethane epoxy to build the bumper up. I was cruising McMaster and found a urethane adhesive by JBWeld no less that I think I've settled on. It's their 'Plastic Bonder' - "urethane adhesive system that provides strong and lasting repairs and works on thermoset, carbon fiber composites, thermoplastics, coated metals, concrete & more." I'll rough up the bumper as best I can, use this to build it up then use the Evercoat Poly-Flex to skim and fine tune the shape.
05 Suzuki DRZ400S
PostPosted: Mon Jun 01, 2020 10:53 am
Bummer on the plastic welding. I've had mixed results with plastic welding, most of it unsuccessful. I'm probably doing it wrong.
Resident Tightwad
PostPosted: Mon Jun 01, 2020 12:24 pm
I've had some pretty good results in the past but they were mostly thermoplastics that lended themselves to being melted/reformed.
05 Suzuki DRZ400S
There are no new unread posts for this topic. Birthday pics and update.
Sun May 27, 2012 11:26 pm
There are no new unread posts for this topic. My 96 SSEi project (lots of pics) Update 6/7, pg 3
zuper8
63
7703
Sun Apr 12, 2015 10:31 pm
haro1225 View the latest post
There are no new unread posts for this topic. UPDATE Finally got around to taking some summer pics!
92BonneSE
Wed Sep 01, 2010 3:25 pm
92BonneSE View the latest post
There are no new unread posts for this topic. Projector Retrofit Done update cutoff pics
2003 SSEi
24
5541
Wed Feb 18, 2009 9:30 pm
Looong4 View the latest post
There are no new unread posts for this topic. Pics Finally! --UPDATE INTERIOR------ COTM
KelvinVV
16
2474
Sat Aug 17, 2013 7:45 pm
