It is currently Tue Apr 07, 2020 2:53 pm
Post new topic Reply to topic  [ 352 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18
PostPosted: Sat Jul 15, 2017 10:05 pm
Appreciate it!
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Sun Jul 16, 2017 10:15 pm
I finally got the new headliner done.. Not without issue either..
Since this is the 3rd time doing this, I wanted to try something new. The soda can weight method works for a lot of the contours but not all of them. So, I figured, why not spend 20 bucks on Plaster of Paris and make molds.
It took me so long to strip the OEM fabric that my wife actually offered to help me. Complete PITA.
I actually screwed up when I went to lay the suede down. There wasn't enough slack in between the front dome light bulge and the back of the sunroof. I cut open the sunroof hole to try and fix it but it ended up creasing the fabric beyond repair. I used an iron to separate the fabric but the board required some repair. The new suede came in over the past week so I went for round 2 with this attempt.
I decided I was going to glue down the fabric in sections, starting with the dome light first, just taking my time to avoid creases. It worked out pretty good.
Hopefully this is the last time for this.
05 Suzuki DRZ400S
PostPosted: Sun Aug 20, 2017 5:44 pm
Year and Trim: 96 SSEi- 157K
Beautiful, definitely impressed by anyone who can do a nice headliner after I did mine (not nicely, btw). Going to do the headliner on my mom's Saturn soon, thanks for the plaster of paris tip! Looks well worth it!!
- Rachael
PostPosted: Mon Aug 21, 2017 12:13 am
I'm not sure why the first couple times I did the headliner went without a hitch, but I had much less of an issue then. What's funny is my wife's Jag needs the headliner redone and she keeps telling me she doesn't notice or not to worry about it.. I think It's because she saw how much of a PITA it was do to on my recent attempts.
05 Suzuki DRZ400S
PostPosted: Tue Jun 26, 2018 7:38 pm
This car has been on the back burner more or less because I'm not sure how much motorcycle seat time I'll get once my wife and I have kids. It's one thing if I get banged up pretty good when it's her and I but another when there's a kid to take care of. I've focused most of my attention to bikes recently and between that plus traveling, not much gets done with the Bonnie. I know for sure this is a forever car so I'll get to it. It'll just take a while.
Since I posted last, I removed the windshield to paint under the top reveal molding (haven't done that yet) and the headliner went in. A new carpet is also in but I still have to trim it up and install all the moldings.
When I was driving the car before the RPMs seemed to want to drop too fast when I was out of gear. It was to the point where it would almost stall. I know there's a table for throttle air follower in TunerCATs but I wanted to be certain I don't have any vacuum leaks. So, I made a DIY smoke tester out of an old paint can, some fittings, air hose and a 5lb pressure regulator. Turns out one of my injectors wasn't seated properly and the back of the throttle body wasn't making a good seal with the UIM gasket ring. I removed all the 14 year old JB Weld and redid the back of the L67 TB to make a better mating surface. The injector in question sealed up with just some cleaning of the bung and lubing the O-rings. With that out of the way whenever I tune this thing next, I'll know that changing the throttle follower table isn't a band-aid.
05 Suzuki DRZ400S
PostPosted: Sun Sep 09, 2018 6:56 pm
I finally got around to trimming the carpet, cutting new door seal spacers to make up for them shrinking and installing most of what's left of the interior. The only pieces left are the passenger foot well carpet trim and the seat rail trim pieces. I know I have that trim piece somewhere but looked for it for a few hours with no luck. I did find an undamaged grab handle I needed and organized what I have for spare interior parts. Not everything is in good shape but I have a hard time throwing out things I know I could make work if I have to.
I know I have more stashed around somewhere but at least now I have a place to put it.
And sorry.. if you see something you need, unless it's HUD related, it's not for sale. I plan on using these spares to maintain the car as long as humanly possible.
05 Suzuki DRZ400S
PostPosted: Sat Dec 28, 2019 10:46 pm
I'm slowly working to getting the car ready for a re-paint.
One of the biggest things to repair other than the windshield channel is re-doing the E39 headlight bodywork. I decided to start over with the hood for the following reasons. Most if not all of it could be fixed but it bothered me enough to want to redo it better.
-Dent from when my strut punched my hood in an accident in 2010
-Dents on the sides from bending the hood back after it flew up in 2012ish
-A dent from my motorcycle bar end
-Passenger side bodywork had a blemish
-Bodywork underneath the hood associated with the headlight molding is rough and started to fail
-Rust developed under the hood since it was only ever primered underneath
They stopped making aftermarket hoods for the 92-99 H-body at some point. Companies still say they have them in stock, but they don't. I wasted a fair amount of time dealing with this. I decided to get a used OEM hood from Ed Morad since the one he had in stock was cleaner than anything I would find in any yard I could reasonably drive to. I used uship.com since Ed stopped shipping larger fragile items a while ago. I paid a premium all said and done but it ended up saving me a lot of time.
The new hood needed to be clearanced underneath and grinded down near the grill to accommodate the larger lenses. New material needs to be added to the hood to extend it over the lenses as it approaches the fenders. The last time I did this, I just tack welded some thick gauge mild steel in for support and then added kitty hair, then bondo. Structurally this help up pretty well on the exterior but I wanted to redo stronger with less filler.
I kept the front section of the hood that was replaced on my 528i in hopes of using as much of headlight cutout as possible. The E39 hood is a bit more narrow than the Bonnie's. Instead of extending the headlight section of the E39 hood to use it, I'll just use the new sections more outboard. After a lot of cutting and checking, I temporarily tacked the driver side transplant section on the hood to see if is close. It just needs to come up a hair on the inside. The extra material on outer edge is intentional for when I square off the end. The new section will come back off, I'll copy it for the passenger side, then start the permanent attachment and body work.
The good thing with this version is I'll have a nice lip to weld on underneath to attach most of the bottom. For the single wall clearanced section underneath, I'm just going to epoxy it along the perimeter, similar to how the skeleton is jointed throughout.
Last time:
Underhood rust and bodywork failing:
05 Suzuki DRZ400S
PostPosted: Mon Jan 20, 2020 11:53 pm
We had a few warm days but that didn't line up with when I was home so no progress on the hood.
I'm able to get my garage about 10 degrees above ambient so I decided to finish up an SSEi suspension air pump install I started a while back. I've had the shocks for 10 years with the Monroe schrader valve kit. A couple years ago I saw an SSEi at the yard and decided to take the pump along with the latch trim with the factory schrader valve on it. I swapped out latch trims and plumbed in the pump in but never wired it up.
To control the pump I chose a 3 way rocker switch so I could air up and down with one switch. I was originally going to cut a hole in my dash trim to the left of the steering wheel for the switch.. Then I started thinking how I don't have a spare dash trim piece in good condition.. If I change my mind down the line or have to use a different switch, I would have to repair it. Then I started thinking about the SSEi dash trim and lo and behold, the SSEi piece has a recessed hole for the HUD controls right where I was thinking of putting the switch. It also has that gain switch under the radio that would be unused, but I'm sure that wasn't too impressive anyway. I found a cheap SSEi dash trim piece on ebay which was actually in better shape than mine. Since I already had 3 HUD control boxes, I decided to hollow one out plastic weld a new face on it and mount the switch in it. This way I could swap switches in the future pretty non-invasively.
For wiring, I cannibalized some pins from my previous 95's fuse box and added a fuse to the driver's under dash fuse panel. I used an existing line originally for the antenna (shaved) for +12 to the exhaust solenoid and I ran a new line of thicker gauge back to the pump. One of the old mounting points for the antenna or the jack box now has a stud for the ground.
Forgive the dust.. and lack of light.
And a video.
If you jack up the volume, you can hear the pump in the background. The lights above the pedals are a part of the 6-speed rewire. They're in place of the shift solenoids.
https://www.youtube.com/watch?v=m-9X7AAuinU
05 Suzuki DRZ400S
PostPosted: Tue Jan 21, 2020 12:25 am
I dig it. When do we get rake photos?
PostPosted: Tue Jan 21, 2020 11:34 pm
Thanks. Honestly, it'll be a while. I need to get the windshield back in before the car is back on the street.
05 Suzuki DRZ400S
PostPosted: Sun Jan 26, 2020 8:26 pm
I got a little more work in on the hood today but unfortunately my MIG gas ran out.
Both hood extensions were trimmed a bit more to completely line up with the hood. All the raw metal mating surfaces were coated with copper weld through primer. The driver's side is completely welded on the top and tacked on the bottom. The plan is to get to the same spot with the passenger side then flip the hood over to completely weld up the bottom on both.
05 Suzuki DRZ400S
PostPosted: Wed Jan 29, 2020 9:13 pm
I took a day off today to get a bit more progress in since it was getting up above 40*.
The passenger side hood extension went on and both sides were fully welded underneath. I'm going to leave two access holes open so I can cavity wax between the hood and extension (after paint). I built up the front corners along the extension too so now there's a nice strong edge on both. I'm fairly content with the fit from right to left. I'll need to build up the passenger side above the hi/lo beams a hair. Some final shaping and checking for high spots will be next followed by a layer of kitty hair.
05 Suzuki DRZ400S
There are no new unread posts for this topic. Birthday pics and update.
Sun May 27, 2012 11:26 pm
There are no new unread posts for this topic. My 96 SSEi project (lots of pics) Update 6/7, pg 3
zuper8
63
6990
Sun Apr 12, 2015 10:31 pm
haro1225 View the latest post
There are no new unread posts for this topic. UPDATE Finally got around to taking some summer pics!
92BonneSE
Wed Sep 01, 2010 3:25 pm
92BonneSE View the latest post
There are no new unread posts for this topic. Projector Retrofit Done update cutoff pics
2003 SSEi
24
5215
Wed Feb 18, 2009 9:30 pm
Looong4 View the latest post
There are no new unread posts for this topic. Pics Finally! --UPDATE INTERIOR------ COTM
KelvinVV
16
2321
Sat Aug 17, 2013 7:45 pm
