It is currently Thu May 28, 2020 6:15 pm
Post new topic Reply to topic  [ 386 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20  Next
PostPosted: Sun Apr 30, 2017 1:31 am
I hear ya. My i30 fenders are a little shaky down there.. If you wanted to fix it without welding, some home depot/lowes sheet metal, tin snips, a drill and some rivets and you're pretty much there. The body cladding would hide it.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Fri May 05, 2017 10:24 pm
The interior patch is seam sealed up, the B pillars are covered in suede, and I repaired a crack in the driver's side drip molding today.
A B C pillars.
There are only a few things left preventing me from putting the interior back in the car. I still need to:
Weld in the patch in the rear seat pan
Put a second coat of Zero Rust over the whole floor
Pull the windshield again (probably could get away with not but might as well)
Paint the upper windshield frame. Right now there's only primer behind the front reveal molding
Install new OEM headliner board redone in suede.. Still need to redo it
Install windshield
Ok.. More than a few. But that's the order of operations at least.
Since I can't do the same thing twice without figuring out a way to do it better, I found the windshield plastic locating supports to help reinstallation. p/n 25654094. My original ones were broken and window welded in place.
05 Suzuki DRZ400S
PostPosted: Sun May 07, 2017 10:23 am
Not too long ago I picked up a NOS passenger drip molding (p/n 25649720) but the driver's side (p/n 25649721) is no longer available. The driver's side is of course in worse shape. It's mainly the rubber strip that attaches to the rear portion of the molding. It shrinks and pulls away. I decided to use a section of the old passenger side rubber to stitch in and repair the driver's.
Here you can see the shriveled part cut off here:
Sacrificial part cut to length
Cut down to match the contour of the other side
Epoxied and supported from the back. I ended up adding more epoxy over all this.
Passenger and Driver's
05 Suzuki DRZ400S
PostPosted: Fri May 12, 2017 7:11 pm
Year and Trim: 96 SSEi- 157K
So, I know I've asked this before, but it's been a few years so.... what are your goals with this project? Obviously, one of your goals is perfection since you're splicing and repairing window moldings, but what else? Car shows? I still think it should get a magazine spread. I loved that fix, by the way, it's something that I would never notice but I know how those details combine to make the car look even more outstanding on the whole.
- Rachael
PostPosted: Sat May 13, 2017 12:34 am
Rachel, as always, I appreciate the kind words.
Power goals while n/a were 13.9 with slicks. I have no idea if that is even realistic but it should be a mid-14s car all day. It's not going to be a fast car but it should have enough power to not suck with a 6 speed.
Aesthetics goals is just to have a good looking car.. But have most people scratching their head as to why they're now into a 1995 Bonneville. And for those that know how the car should look to notice maybe 20% of what I did. I'm basically my worst enemy. I want to look at everything I do and never wish I did it any better or different.
Shows? Yeah eventually but I'm still quite a ways off.
I also want the car to be dead reliable. Aside from the electrical gremlins I might have made for myself by re-wiring the whole front end, this goal is the easiest.
Some more updates from today.
I got the hole in the seat pan welded up. It's Zero Rust coated from underneath but I still have to do a second coat. The frame rail actually had decent access to the underneath.
While fixing the seat pan I saw more rust and I started to fix it.
I need to clean that up a bit more before paint. I also need to drill a hole for the lower rubber screw and the plan is to cavity wax through that hole. I'll seam seal it from the back in the wheel well too.
05 Suzuki DRZ400S
PostPosted: Sat Jun 03, 2017 6:57 pm
Year and Trim: 1995 Pontiac Bonneville SSEi
2003 Bonneville SSEi
nice ride I have a 95 SSEi black on black. I am seriously considering just giving it away parking it in the yard with a free sign on it. I'm having trouble routing all of the vacuum lines, and I mean every single one from the canister to the throttle body stuff up on the supercharger and back to the firewall I was hoping that maybe you could post a couple of pictures of how they run all the way through there, because your car is the closest I have found to mine. I would greatly appreciate it thank you. you can text them to me if you would like or you can email them to me or send them on here. My # 740-577-5683. Email gratefuldude2001@gmail.com
Bonnie lass has been setting for far too long
PostPosted: Sat Jun 03, 2017 11:46 pm
Email, texting, and private messages won't help other people. That, and I'm far from the best option for input on S1 L67 vacuum routing.
Here's a post in the proper section and I'm sure other people will help out more.
1992/topic50639.html
05 Suzuki DRZ400S
PostPosted: Fri Jun 09, 2017 11:53 pm
I went to finish the small patch on the driver's rear door seal but the few spots of wheel well rust were staring me in the face.. that lead to more metalwork.
For the door seal metal, I actually ended up welding it from the back via mirror to get it sealed up instead of seam sealing it. When grinding down the rust spots in the wheel well, there were two spots that needed more than a grinder to fix. The one section needed new metal worked on both sides of a pinched seam. The other section near the shock turned out to have good metal behind it so I just welded the superficial metal to the good metal underneath. Eventually I'll have to go back and re-do the wheel wells with the proper coating but for now it has 2 coats of Zero Rust.
I did re-coat the areas I repaired a month ago. All that's left to close out these repairs is cavity waxing the door seal repair through the mounting hole drilled in the fresh metal and seal sealing from inside.
I also started putting a second coat of Zero Rust on the interior. The rear seat pan is done. The rest of the floor is next.
05 Suzuki DRZ400S
PostPosted: Mon Jun 19, 2017 12:13 am
There's not many pics but I actually spent a fair amount of time on the car over the past few days.
The breakdown:
-Threw a 2nd coat of Zero Rust over the interior floor
-Wired in the rear SSEi speakers I got at the yard
-Installed SSEi rear deck
-Saw one driver's side floor access panel pushed through the rubber/tar sealing mat. No corrosion luckily. So I removed the metal, painted it, and installed Hush Mat over it to seal. (You can see the hole on the one pic below)
-Hush Mat'd the hole in the front driver's patch panel
-Laid the new carpet out inside for a couple days to let it settle
-Started to install the carpet. Driver's seat is in.
I still need to cut the carpet for the passenger seat and down the sides yet. The last time I installed a carpet with the nose higher than the rear and it ended up with slack at the end of the exhaust tunnel. I also ended up trimmed the one side a little to far. So, I did the install this time with the nose lower and worked the carpet from the rear seat forward. I'll leave the sides long until it settles.
I haven't had carpet in the car for like 6 years because of water leaks.. It might not seem like a big thing but it's a nice milestone for me.
The rest of the interior will go in easy enough. The A/B/C pillars will stay out till I redo the NOS headliner board and pull the windshield.
Slowly but surely.
05 Suzuki DRZ400S
PostPosted: Sat Jun 24, 2017 7:54 pm
All the seats and the center console are back in. I'll have to get a pic of that at some point.
I decided to tackle a small project I've been thinking of doing for a long time.. Belt wrap with the re-routed belt for my electric water pump has always been lackluster. High rpm shifts or low rpm dips always seem to make it slip a little. So, I decided to make another idler pulley in a similar location to a 00+ H body supercharger idler. I did a little cardboard mock up, drew the part in CAD, tested, tweaked and had S&W Race Cars waterjet the bracket for me. They're the same folks I used for waterjetting all the F40 associated mounts I designed. I also had them spin down some stand off spacers for it too. Once I got the parts back, I tapped the pulley spacer, did a little tweaking and found a belt that would work.
05 Suzuki DRZ400S
PostPosted: Sun Jun 25, 2017 11:32 am
I like it.
PostPosted: Tue Jun 27, 2017 9:21 pm
Thanks!
I'm hoping to work on the headliner next.
05 Suzuki DRZ400S
PostPosted: Wed Jun 28, 2017 12:04 am
Year and Trim: 99 Regal GS
You're doing amazing work! It's really giving me more motivation to fix some of the smaller issues on my projects!
1999 Buick Regal GS 3.4" pulley,SLP headers, fwi, pnp, gemini chain w/ other trans mods, 12" brakes, GR2's, STB's, 34mm front sway bar; The Summer DD
1982 Pontiac Grand Prix L36 and an hx35 turbo; It's pretty quick Mod list here
PostPosted: Wed Jun 28, 2017 8:36 am
That's awesome. Anymore I feel like OCD has me working at a snail's pace. It's very cool to hear what little I do get done still motivates.
05 Suzuki DRZ400S
PostPosted: Thu Jun 29, 2017 9:25 pm
From earlier today on a Home Depot run.
05 Suzuki DRZ400S
PostPosted: Fri Jun 30, 2017 5:42 pm
Year and Trim: 2001 SSEI/2007 TBSS/2004 CTS-V
Looks great. =D>
"Big 3", Tint
PostPosted: Mon Jul 03, 2017 1:01 am
Year and Trim: 1997 SSEi
Man, I haven't been on this forum in ages but awesome to see you're still working on/driving the car. Amazing. I love the car!
PostPosted: Mon Jul 03, 2017 10:58 am
Thanks guys!
05 Suzuki DRZ400S
PostPosted: Fri Jul 14, 2017 1:45 am
Year and Trim: Member since Jan 2003
Great to see how far this car has come! Awesome work!
-driverjohn2005
"Gravenge" -1992 Pontiac Bonneville SSEi- Sold 4/29/12 to "myfirstbonnie"
Current Rides: 2015 Mitsubishi Outlander Sport GT AWD & 1999 Ford F-150 Lariat 4x4 SuperCab
PostPosted: Sat Jul 15, 2017 5:50 pm
Year and Trim: '97 SSEi
I'm totally biased here but GO USA!! Bonnie's got it going on.
'97 SSEi, Majestic Teal / Beige interior, Bose, HUD, iPod ready! - SOLD! :sad: Check it out!
There are no new unread posts for this topic. Birthday pics and update.
Sun May 27, 2012 11:26 pm
There are no new unread posts for this topic. My 96 SSEi project (lots of pics) Update 6/7, pg 3
zuper8
63
7693
Sun Apr 12, 2015 10:31 pm
haro1225 View the latest post
There are no new unread posts for this topic. UPDATE Finally got around to taking some summer pics!
92BonneSE
Wed Sep 01, 2010 3:25 pm
92BonneSE View the latest post
There are no new unread posts for this topic. Projector Retrofit Done update cutoff pics
2003 SSEi
24
5530
Wed Feb 18, 2009 9:30 pm
Looong4 View the latest post
There are no new unread posts for this topic. Pics Finally! --UPDATE INTERIOR------ COTM
KelvinVV
16
2468
Sat Aug 17, 2013 7:45 pm
