It is currently Fri Jul 23, 2021 2:00 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Mon Sep 09, 2019 12:10 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
No progress on body work yet, still waiting to find parts (getting time off work is fun...)
In the meantime, I've done the standard fix for the gauge cluster capacitor - it had just started to prevent the cluster from turning on so hopefully I got to it in time to prevent stress or damage to the rest of the components in the cluster.
The brakes started squealing the other day, and like every other brake caliper from gm in the early 90's I bet the fronts are both seized and only wearing the inside pad... So of course that means it's time for a brake upgrade. There's not much info to go by aside from one person back in the day that made a kit for a 12" rotor, for $450 or such. However, I think I have the junkyard solution. The Olds was discontinued in 1992, but the Eldorado lived on to get an updated front end that shares the floating caliper design of the late 90's-early 00's cars - which means if the 97+ Eldorado knuckle bolts in then I can put the super common CTS/STS dual caliper 12" setup on this car too. All the ingredients are there to say it will - struts appear the same mounting, wheel bearing is the same (changed from threaded to unthreaded mount holes, but otherwise identical) ball joints taper and tie rods are the same, etc... There are no pictures to go by, but I think it's going to be close.
I wasn't planning to do a brake upgrade, but after the front end thing I think it's worth it. Brakes on this car have felt lackluster from day 1, and the Mastercraft tires aren't helping.
L67 Cavalier
PostPosted: Mon Sep 16, 2019 2:22 pm
'05 STS-4
'97 LeSabre
Test fitted some parts over the weekend, and made the build plan:
That's the '97+ Eldorado knuckle and strut on the Olds. Everything looks like it lines up the way it should, but I'll have to get creative if I want to keep my barely used front wheel bearings with these knuckles. They don't have threaded mount holes like the Eldorado ones do, so I'll need to see if I can just put a longer bolt and nut through them or I'm stuck with the Eldorado ones.
The JL9 11.9" rotor, aluminum dual piston caliper setup from the STS (& CTS) look like they barely fit under the 16" olds wheels. With new pads I think I'll need a 1/8" wheel spacer, maybe a 1/4" spacer. Tape weights barely clear the caliper.
The spring, mounts, strut bearing and mount from the olds look like they will bolt up to the Eldorado strut. Same with the sway bar end links. I don't know if the spring rates are different between the two cars, but it looks like there is an AC Delco 'performance' strut (503671/2) for the Eldorado that is hopefully the same or better than the FE3 package on the Olds.
Brake hose on the olds points down and is around 8". The bigger caliper needs about 3" more hose, the closest I could find was the Delco 18J1650 - 15" hose. It might be a little bit too long, but the bend on the caliper side should point it in the right direction.
Anyhow, parts are soaking in the parts washer so I can clean them and get them powdercoated while I wait for the new struts and hoses to come in. Expect to see more photos soon!
Also, finally found something:
L67 Cavalier
PostPosted: Mon Sep 16, 2019 2:41 pm
Definitely can't wait to hear more about the front suspension progress! I also had to take the chance to get a picture of the Trofeo and SSE when you parked it there. :lol:
91 Buick Riviera | S2 L67 swap/4T60E | 124k mi | Antelope Beige Metallic w/Tan Int | Beat-up Beater / Cool Digital Dash
92 Pontiac Bonneville SSE | L67/4T60E | 75K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule / Storage Occupant
92 Chevy Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Rusty Storage Occupant
03 Buick Park Avenue Ultra | L67/4T65E-HD | 197K | White Diamond Metallic w/Shale Int. | Rust Free Southern Sourced Storage Occupant
99 Chevy Tahoe LT | L31/4L65E | 246k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig / Tow Pig / Portable Concert Hall
04 Cadillac Seville STS | L37/4T80E | 216k mi | Red Jewel Tintcoat w/Shale Int. | Storage Occupant Too
05 Cadillac Deville | LD8/4T80E | 146k mi | Black w/Two Tone Tan Int. | Livery Pkg Daily
James May wrote:
Hello.
PostPosted: Mon Aug 24, 2020 10:21 pm
'05 STS-4
'97 LeSabre
I kinda just threw this together this weekend..
90% bolt on. The only modifications I had to do was the sway bar end link hole in the new AC delco struts from the eldorado needed to be drilled to fit the '92 end link (95+ are a tapered fit like a ball joint or tie rod end).
Fit to the Olds wheels is super tight. A 1mm spacer is all you need tight. It works just fine in the driveway, but I ordered spacers anyway tight.
With the JL9 brakes, tape weights on the wheel clear just fine, it's the offset that's the issue.
Brake pedal travel is better then stock. It takes less effort to get the same feel, and at the same time far more effort to lock up.
L67 Cavalier
PostPosted: Sun Sep 27, 2020 12:05 am
'05 STS-4
'97 LeSabre
Ended up with hub-centric 3mm spacers on the front, all of that is working out good now.
Rear brakes are done now as well:
End result is that this car stops almost as good at the Camaro. I can't believe that these are the same tires that locked up last year and resulted in the front end disfigure. The biggest difference is the brake pedal response is more predicable. It takes zero pedal travel or effort to initiate the braking response, but unlike the OE replacements on this car the JL9 brakes seem to take far more pedal effort to reach lockup and deliver 2x's as much stopping power. I'm guessing the rotors on this car were warped and grabbing before, not sure why else it stops in half the distance it would have before.
L67 Cavalier
PostPosted: Sat Oct 10, 2020 7:35 am
Year and Trim: 1990 SSE
Here I thought I was doing something special when I installed drilled rotors. Great job.
There are no new unread posts for this topic. Olds Toronado: runs great, then dies and doesnt restart...
VBCSpangler
Fri Jul 03, 2009 10:35 pm
There are no new unread posts for this topic. 1985 Oldsmobile Toronado engine swap
VBCSpangler
53
10479
Tue Mar 03, 2009 2:19 am
VBCSpangler View the latest post
There are no new unread posts for this topic. 2 pic wonder of my Olds
Ponch 04
Tue Aug 11, 2009 12:02 am
BonneMe View the latest post
There are no new unread posts for this topic. 99 Olds Silhouette Grounds
azu
Sat May 16, 2009 10:51 pm
azu View the latest post
There are no new unread posts for this topic. The granny cruiser - 1991 Olds 88
Hotwheels
Sat Nov 13, 2010 1:07 am
redmetrix View the latest post
