It is currently Wed Jan 23, 2019 7:32 am
Post new topic Reply to topic  [ 61 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: It's official: 05 STS4
PostPosted: Tue Feb 21, 2017 10:18 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I'm a looney!
Meet the newest member of my fleet:
2005 Cadillac STS
Northstar, AWD, navigation, sun roof, black on tan.
Got it for $2600
The bad (paging Lane!):
-Clicking noise from the front passenger side when you launch or go WOT, sounds AWD related
-needs struts and mounts soon enough
-heated steering wheel doesn't work
-Heated seat on front drivers side weak
-airmix actuator or stepper motor on DS not working, air blows out cool no matter what setting
-loose shifter
-front bumper cover paint needs re-done
-condensation in the headlamps, though they are not hazed and aimed too high.
-remote start not working
-brake light row of LEDs out on one side
The good:
Super clean, only two rust spots on the entire car and nothing on the underbody, engine is running great, trans shifting smoothly, drives perfect, everything is working.
Also, I'm in love with the Northstar.
Runs:
Doesn't run:
 Post subject: Re: It's official.
PostPosted: Wed Feb 22, 2017 12:31 am
You are a looney! Nice price..hopefully you can correct everything with little headache...
PostPosted: Wed Feb 22, 2017 1:07 am
I'm a looney!
2005 Cadillac STS
Got it for $2600
-loose shifter
The good:
I are jealous of the price. I can't even find a decent previous gen FWD Seville STS for that price unless it's some beat up hoopty...
Most likely front CV joint related. Not overly familiar with that issue.
These can be costly
You're SOL here. Unless you take it apart and try to fix it yourself or find one in the boneyard (which if it hasn't failed it inevitably will). Not sure about the non-V versions, but for us V owners, GM no longer has replacement steering wheels for 2006 - 2007 owners. I seem to recall non-V owners in the same boat.
I'm sure you could just pull the seat cover and inspect the element for shorts
Not familiar with this issue.
-loose shifter
Lots of shifter problems with these cars. Most common is the inability to shift out of park. But a search on Cadillacforums would get you a ton of info.
Standard body work
Common issue. I believe you can disassemble just like any other headlight assembly. Otherwise if you want new, these housings are VERY expensive.
My guess is that there is a Body code (a communications issue on the network or something similar) that is causing this. Clear it and it will work. Mine will sporadically have this hiccup. I go in with the T2 and clear the body codes and it works again. There are a lot of body control electronic gremlins on this car. Sometimes I also lose my express down/up feature and express close on the sunroof until I clear these codes...
Not sure if there is a fix because I haven't seen something like this posted. I've been behind a few with one or two LED's out. It just might be easier to find another.
PostPosted: Wed Feb 22, 2017 1:18 am
'05 STS-4
'97 LeSabre
Sounds like the clicking noise is the transfer case chain jumping. I'd have to dig into that one.
Runs:
Doesn't run:
PostPosted: Wed Feb 22, 2017 1:26 am
Which would be indicative that it's stretched.
PostPosted: Wed Feb 22, 2017 11:16 am
'05 STS-4
'97 LeSabre
Looks like GM parts direct has a listing for the heated steering wheel, it's $500.
Struts: $500 each
Guess I'll be swinging by the cadillacforums to see what I can find.
Runs:
Doesn't run:
PostPosted: Wed Feb 22, 2017 11:54 am
Can you get it though? That is the $64k question. Yours you may be able to get. Yours has wood trim inserts around the rim. It's the same design wheel, but ours doesn't have the wood trim.
PostPosted: Wed Feb 22, 2017 3:13 pm
'05 STS-4
'97 LeSabre
So if the chain stretches, then starts skipping, how many dozens of metal shavings are floating around in the transfer case? I'm guessing I'd have to replace the sprockets and the chain, and any bearings at that point.
Then I find on car-part that I can get a used transfer case with half the miles on it for ~$300. The new chain is $200. So, I might just go that route.
I need a tech 2. lol.
Runs:
Doesn't run:
PostPosted: Wed Feb 22, 2017 4:42 pm
I'd just replace the whole thing. You don't know what you're getting into without opening it up. So to answer your first questions... I don't know. The fact that it still seems to work in normal driving, I would say that there probably isn't a lot of damage... Yet.
PostPosted: Thu Feb 23, 2017 12:06 am
'05 STS-4
'97 LeSabre
Where is the RPO tag supposed to be? I can't find it...
Runs:
Doesn't run:
PostPosted: Thu Feb 23, 2017 2:40 am
Under the spare tire cover in the trunk.
PostPosted: Thu Feb 23, 2017 10:28 am
'05 STS-4
'97 LeSabre
So that's missing. Guess I'd have to take the VIN to the dealer at this point?
Runs:
Doesn't run:
PostPosted: Thu Feb 23, 2017 11:45 am
Seriously... WTF is someone gonna do with a spare tire cover? I haven't looked at mine lately so I'm a little foggy (it's not something one normally goes and checks out), but I seem to remember a trap door setup under the carpeting.
PostPosted: Thu Feb 23, 2017 11:51 am
'05 STS-4
'97 LeSabre
I have the spare tire cover, lol. It doesn't have the tag on it.
Runs:
Doesn't run:
PostPosted: Thu Feb 23, 2017 12:19 pm
There are a couple stickers on that cover. The tire/jacking thing, the SPID, and a few others... Odd...
PostPosted: Thu Feb 23, 2017 1:45 pm
Year and Trim: 2004 GTO
What about on the bottom of the trunk lid by the latch? That's where the one on the Grand Prix is.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Thu Feb 23, 2017 1:57 pm
Year and Trim: 99 Regal GS
If you're looking for RPO codes, I have a compnine account that I can run VINs through and get those.
1999 Buick Regal GS 3.4" pulley,SLP headers, fwi, pnp, gemini chain w/ other trans mods, 12" brakes, GR2's, STB's, 34mm front sway bar; The Summer DD
1982 Pontiac Grand Prix L36 and an hx35 turbo; It's pretty quick Mod list here
PostPosted: Thu Feb 23, 2017 2:13 pm
No room. Plus the lid has a form fitted carpet on the underside.
PostPosted: Sat Feb 25, 2017 11:57 am
Matt, if you send me the last 8 digits of your VIN I can get all your build info at work for nothing, along with a VIS showing what was done to it while it was under warranty, yadda yadda. just throwing the offer out there if ya still need any information. :beerchug: Hope it treats you well, it looks nice!
92 Bonneville SSE | L67/4T60E | 72K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule
92 Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Summer Daily Driver and Future Turbo Racekar
03 Park Avenue Ultra | L67/4T65E-HD | 188K | White Diamond Metallic w/Shale & Cashmere Int. | Rust Free Southern Sourced Daily Driver
99 Tahoe LT | L31/4L65E | 237k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig and Portable Concert Hall
04 Cadillac SLS | LD8/4T80E | 186k mi | Red Jewel Tintcoat w/Shale & Grey Int.
09 Malibu LT | LE5/4T45E | 205K mi | Seafoam w/Blk Int.
13 Explorer XLT | 3.5/6F55 | 141k mi | Kodiak Brown w/Blk Int.
James May wrote:
Hello.
PostPosted: Sat Feb 25, 2017 6:53 pm
'05 STS-4
'97 LeSabre
Vin last 8 is50233334
Also scanned the car today!
C0040
P1793
P0897
P0446
P0335
P0507
P1101
P0068
P0101
P0420
P0430
P0300
P0171
P0174
Um......... yeah. Lane?
Runs:
Doesn't run:
There are no new unread posts for this topic. Louis Vuitton Official Website 6014pul
uomhlqjvg
Fri Aug 10, 2012 9:45 pm
uomhlqjvg View the latest post
There are no new unread posts for this topic. Pontiac Bonneville Club Official Cycling Thread
LeSabreUltra
31
3465
Fri Jul 01, 2011 1:57 pm
