It is currently Fri Feb 15, 2019 5:16 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Mar 05, 2017 11:38 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Well, I tore into my first ever Northstar engine this weekend. On the docket for work was intake gaskets, starter motor rebuild, spark plugs, throttle body and MAS cleaning, throttle body gasket, etc. 0171 and 0174 are the main two codes I'm hoping to kill off. We'll see if any others go too.
Other than breaking a few plastic clips (3D printer is already busy with replacements) everything seemed to go well. I didn't find any damage other than rotted out rubber. I did have to replace the vacuum lines to each valve cover, they just crumbled apart when I tried to remove them. Other fun findings: none of the intake manifold bolts were torqued down... None. They were less than finger tight. So, I want to say, I found the problem. Also the fuel injector O-rings were as hard as rocks and cracking, managed to get them out without casualties but it was close. The brake booster hose seems a little loose, like a hose that's gone soft from soaking in oil. So I'll have to replace that soon but for now it's going to have to work.
Well, here it is, freshly washed under the hood as much as I cared to do:
And it's out! Took me maybe 45 minutes (going slow), I would say getting to the starter on this was actually not much harder than a 3800 is. And don't worry, I cleaned all that nasty out of there:
A picture of everything getting put back together. Seems like the intake coupler is something like 3.75", but I managed to get a 3.5" silicone coupler on. The rubber one hadn't failed yet, but it was not in the best of shape either.
Whoa!
The spark plugs have me a little annoyed. I'm told the AC delco 41986 is the OE plug. That's what I bought to replace mine. The 41986 is a heat range 16 plug with a .040" gap. It's a really nice plug, appears to have a stainless steel shell, which is an appropriate application for a fastener into an aluminum thread. The plugs that were in the motor are obviously not original. They were the 41950, which is listed for use in this application, but it's far from the same plug. Heat range is 12 and the gap is .050", and the shell is just plated steel. I soaked them in PB blaster before trying to remove them, luckily I didn't have any stripped threads, but I measured an average of .070" gap and one plug had heavy white deposits on it (drivers side rear-most plug).
Now, I'm not an expert, but I know enough that dropping heat ranges is not something you normally do with an un-modified engine. To me it looks like there were issues with the plug being able to self clean in this case. This is the first time I've found plugs to be wet like this.
But after all of this, I got it back together and took it out for a spin. The engine seems to idle a lot smoother, so we'll see what happens next!
For arguments sake. If the GXP is a size 10 engine in a size 4 dress, is the STS a size 10 engine in a size 7-1/2 dress?.... :dontknow:
Runs:
Doesn't run:
PostPosted: Sun Mar 05, 2017 11:59 pm
That looks fairly easy to work on. Definitely easier than this stupid Ford intake I did this weekend. Spent about 5-6 hours on mine.
That's weird on the plugs. How can a plug 4 heat ranges colder be listed as a replacement? You probably just cleared half of your codes this weekend.
yourgrandma wrote:
High
PostPosted: Mon Mar 06, 2017 11:21 am
'05 STS-4
'97 LeSabre
I'm hoping that this fixes the 0068, 0101, 0171, 0174, 0300, 0507, and 1101. That leaves me with 7 codes. Two are from the RF WSS, one from bad trans fluid, two are covered under extended warranty (I was told by the dealer I have until 200k miles or June of this year to get it done). That leaves two that I'll have to do some real diagnostic work to determine what's going on. I'll have to get my own tech-2 this year.
I haven't been under the car yet, but I'm secretly hoping that I don't have to take the exhaust down to service the transfer case. If I do, it's going in for the extended warranty first (let the dealer break rusty exhaust bolts so I don't have to deal with it!)
Runs:
Doesn't run:
PostPosted: Mon Mar 06, 2017 11:45 am
In the RWD layout, they aren't as bad as the FWD. The only problem that annoys me, is that plastic wiring harness gizmo on the passenger side, next to the cam cover blocks access for any room past the strut tower.
The heat range plugs was probably cause of your misfire.
What are the torque specs on those manifold bolts? 89 in/lb? I honestly forget. If it's around that, it is the same freaking problem the cam covers have. A couple heat cycling's and they're loose again. Grrr...
PostPosted: Mon Mar 06, 2017 12:54 pm
'05 STS-4
'97 LeSabre
Lol, torque spec? I just go by feel on bolts that small, I don't have a 1/4" drive torque wrench yet. They have a metal sleeve to prevent you from cracking the plastic manifold, so once they bottom out I just give them a little extra with the 1/4" ratchet. If they are prone to backing out I might try some purple or blue threadlock.
Runs:
Doesn't run:
PostPosted: Mon Mar 06, 2017 1:57 pm
Yea, that is the same as the Cam Covers. I think they're called "Shoulder Bolts" or something like that. As such, they're usually around 89 in/lb. or 7.4 ft/lbs. of torque.
PostPosted: Mon Mar 06, 2017 3:35 pm
'05 STS-4
'97 LeSabre
Getting ready to do an oil change. Was there ever a longer version of the PF61 oil filter, or is the PF61 the biggest I'll find?
Runs:
Doesn't run:
PostPosted: Mon Mar 06, 2017 3:39 pm
PF61 is the only one I know of on those engines. I think 58 and 59 are close.
If you want to experiment, go get a PF26 (what I have on mine). It is the size of a small coffee can. Not sure if it will fit, but...
PostPosted: Tue Mar 07, 2017 9:37 pm
'05 STS-4
'97 LeSabre
silly question, I know... How do I reset the oil life monitor?
Runs:
Doesn't run:
PostPosted: Wed Mar 08, 2017 1:31 am
With the buttons to the left of the gauge cluster. Scroll through until you get to the OLMS, then another one of those buttons resets it.
PostPosted: Fri Mar 10, 2017 11:00 am
'05 STS-4
'97 LeSabre
Opinion time.
Universal K&N filter
-or-
aFe dry filter (21-90008)
Runs:
Doesn't run:
PostPosted: Fri Mar 10, 2017 1:53 pm
Year and Trim: 2004 GTO
Go with the cheaper option. The maf on the Passat is literally right above the filter inside the air box and so far I haven't had an issue with the k&n filter.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Fri Mar 10, 2017 4:13 pm
Cheaper. There is NO flow difference between filter elements. Other than reusability, there isn't any point...
Years back I did back to back dyno pulls with my Camaro. Pull #1 was with a K&N filter replacement. Pull #2 was with a regular paper Fram.
The regular paper Fram did 2 more RWHP, which I would consider negligible in real world.
However, if you're redoing all the plumbing and then going to a cone filter for better laminer flow, then it's a different story. A reusable works a little better.
PostPosted: Fri Mar 10, 2017 7:20 pm
'05 STS-4
'97 LeSabre
It looks like if I posted about putting a K&N on my STS on the caddy site I would have been roasted, lol. So I was just curious what dry filter options there were, and lo and behold there's $10 ebay filters or $60-$100 racecar filters, nothing in between.
The wife likes green, I saw some green air filters, I'll get one of those. I'm just doing this for the sound, so the only real changes are going to be a cone filter and a modified airbox to retain some semblance of cold air intake. Don't feel like relocating the MAS for this.
Runs:
Doesn't run:
PostPosted: Sat Mar 11, 2017 12:52 am
Yea, panel filters are a waste. If you're doing it as part of a whole CAI kit, obviously going cone, it isn't an issue.
PostPosted: Sat Mar 18, 2017 9:10 pm
'05 STS-4
'97 LeSabre
I decided to grab a spare transfer case (130k miles) and rebuild it on the side to reduce the amount of down-time on this car.
I tore it down this weekend to see what's what. The chain was stretched just a little, nothing worth worrying about, but why come this far and not change it? Some pieces are press-fit so they required various gear pullers to remove:
I wish though that I'd seen this before I started. I'm going to go out on a limb and say that this is most likely the same issue mine is suffering from right now...
So I ordered a new input shaft, new seals, and might order a new output sprocket as the one in this transfer case had a chip in one of the lobes.
Runs:
Doesn't run:
PostPosted: Sun Apr 09, 2017 4:46 pm
Things are happening today.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Sun Apr 09, 2017 10:03 pm
Which did it end up being? 4476? Or 4479?
PostPosted: Mon Apr 10, 2017 4:27 pm
It was the 4476.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Mon Apr 10, 2017 5:15 pm
I didn't realize that a half quart was all. My transfer case in the Suburban by way of comparison, is something like 2.5 quarts.
There are no new unread posts for this topic. Louis Vuitton Official Website 6014pul
uomhlqjvg
Fri Aug 10, 2012 9:45 pm
uomhlqjvg View the latest post
There are no new unread posts for this topic. Pontiac Bonneville Club Official Cycling Thread
LeSabreUltra
31
3492
Fri Jul 01, 2011 1:57 pm
Users browsing this forum: Google [Bot] and 2 guests
