It is currently Sat Jan 23, 2021 6:11 am
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Mar 20, 2018 2:18 pm
Thank you!
PostPosted: Fri Apr 20, 2018 9:50 pm
So unfortunately I toasted my 350 top end. My ignition was 1.85ish (should be 1.8mm or less) when checked after it happened and I ran a bit without realizing the slides were in backwards.. Live and learn. There was a meet coming up about 35 miles away I was dead set on going to. So, I took my old 250 top end, painted it, did a quick polish on the fins and installed with it re-timed to 1.77 BTDC. I screwed up the top end on a Thursday afternoon, had it apart that night, cylinders went back out to Chuck (guy who did the machining) Saturday morning and it was running again, jetted in as a 250, by Saturday night. Chuck is working on the 350 top end and the good news is it wasn't super bad.
The meet got rained out so I took my forks apart for a spring and emulator upgrade. These forks came off of ebay with good stanchions, one sort of polished tube and the other not so much. Since it was all apart, I decided to polish the one and re-do the other. Here's some pics of the process then a comparison of the one leg I got through and what it used to look like. I started at 220, when through 320/400/500/600/800/1000/1500 mostly hand sanding and I used a dremel with directionally wrapped sandpaper to do the tight radii. Then buffed it out. The one leg took about 6 hours.
PostPosted: Sat May 05, 2018 10:53 pm
The second fork took way longer than the first but it's all together and on the road again.
For the fork rebuild I went with 0.8kg Sonic springs with 10mm of preload, 15w oil at 130mm height and Race Tech emulators with silver spring and 3 turns of pre-load. It feels great so far.
PostPosted: Tue May 08, 2018 9:26 am
Year and Trim: 2003 SSEi
Well, that sucks! "The slides were in backwards..." - are you talking about the carb throttle slides? If those are in backwards it would be like having the throttle about 1/2 way open. The engine would start racing pretty good once it started! I don't recall, does your bike have the auto-oiler, or do you have to premix the gas? For a road bike I'm guessing auto-oiler. Do you have some way to control the metering of the oil?
I would have spent about 5 minutes on a fork tube then said screw this. I admire your tenacity to do something like that. They look great.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Tue May 08, 2018 11:17 pm
Yeah the throttle slides were in the wrong carbs and the cutout that's supposed to be pointed away from the engine was pointed toward it. I think it might have been like that the whole time. I didn't think much of it before since they only go in one way... but they will go in the wrong way in the wrong carb. I could get it to idle ok like that too..
Yep, still have the autolube system. It's hooked up to the throttle cable and it's adjustable. I actually had to back it down to get it within spec. It still smokes pretty good too.
Polishing aluminum.. blows. Lol. I have a tons of hours into my Bonneville stuff.
PostPosted: Thu May 10, 2018 5:47 pm
95naSTA wrote:
... they will go in the wrong way in the wrong carb. I could get it to idle ok like that too...
Now that's just weird. Why would they go to the trouble to build a left and a right carb? Maybe to get to the airmix screws and idle speed screws, I reckon. That had to affect your throttle response off the bottom and in the mid-range. WFO wouldn't make much difference, but the slide cutaway does have an impact on the lower end of the metering spectrum. I think that would make it rather rich in that range. Might explain the blackish piston.
And speaking of black, that's what everything turns when buffing aluminum - especially your hands. :)
Resident Tightwad
PostPosted: Sun May 13, 2018 11:49 pm
Throttle response off the line was bad but I just thought it was due to the huge pipes meant for a 350-400 on a 250.
I got smart and started using gloves when polishing aluminum.. Also did it all outside.
PostPosted: Thu May 17, 2018 12:46 pm
95naSTA wrote:
I got smart and started using gloves when polishing aluminum...
#-o Why didn't I think of that? :lol:
Resident Tightwad
PostPosted: Thu Aug 09, 2018 12:05 am
This thing made short use of the redone 350 top end again a couple weeks ago.. this time I had a likely culprit.
That rip was out of direct sight.. The one piston started to melt and it'll likely require an overbore this time. It obviously sucks but I slapped my old 250 top end back an an hour or so after finding the damage and it's back up and running.
I'm in no hurry to get this thing running as a 350 again this season. It's fun as a 250 and I know I can rip on it without it crapping out. That said, I hate not having a quantitative form of measurement not telling me what's up. I have a wideband on my daily bike for efs sake. Widebands don't last long in 2 stroke format and they're not accurate at low RPM (2 strokes sometimes 4 stroke). EGTs are widely used but I really don't want to hack up my JL chambers and add mess to the bike. So, Cylinder Head Temperature it is. I picked up 2 Trail Tech CHT sensors for both cylinders to monitor temps and get an idea of what safe is. The sensors replace the spark plug crush washers. Looking around, they're not super popular on bikes but it seems air cooled engine aviation guys are really into these things.
The things are self powered, have the time and even show max temp. A quick test let me know that my one plug was fouled and once that was addressed, I got a steady 10-15* temperature difference between cylinders. I'll be swapping the sensor leads and then comparing compression to figure that one out. Either way, I'm happy to have something other than plug color to give me a heads up on how the bike is running.
PostPosted: Thu Aug 09, 2018 9:56 am
When it's running. :poke: :)
So are you thinking it sucked a fly or some dirt in there? I suppose, being downstream from the air filter, it could have leaned that cylinder out a bit; the filters probably restrict the intake of air slightly.
Resident Tightwad
PostPosted: Thu Aug 09, 2018 10:36 am
Haha. Hey this thing was back up and running within hours of both melt downs.
I’m thinking the one side leaned out but who knows.
PostPosted: Wed Sep 16, 2020 11:27 pm
One last hurrah on this thing today before it gets stored for a while. I clocked just under 100 miles up one of my favorite areas in PA, basically everything just west of the Delaware River from Washington's Crossing up to Easton. It's beautiful up there.
The cylinder head temp sensors I added in one of my last posts have come in handy on some highway stints too. They're definitely a nice tool to have.
PostPosted: Thu Sep 17, 2020 10:34 am
Beautiful pic. Very green in that part of the country. While I'm sure when the Northeast was named "New England" it wasn't because they thought it looked like England, but that picture does remind me of Wales. (I mention Wales as being part of England at the risk of inciting the wrath of any Welch persons who may run across this post!) :lol:
Bike's still looking sweet, but I'll have to admit 100 miles would probably be about all I could take on the old girl. :)
Resident Tightwad
PostPosted: Fri Sep 18, 2020 12:38 am
Lol. I'm a McPatrickO'FlanneryMagee so no issue here. I've never been outside of London and my 23 year old memory of Ireland is fading. So I don't have much to really compare it to in totality. Now if there were some industrial revolution relics along the same road, it would be like NZ.
I'm with you on the 100 miles being the cap and I'm 36. It was a lot to do on that bike in 4 hours. I was getting leg cramps on mile 40 or so but was able to stretch it out. I have a feeling that in a few years stretching might not do it anymore.. lol. In all honestly it made me more glad I got out and did it now.
PostPosted: Fri Sep 18, 2020 10:08 pm
When you're within spitting distance of 60 after 100 miles on that you'd have to come to a rolling stop and have someone lift you off the bike and straighten out your arms & legs. I'm active and consider myself to be in reasonable shape, but age is a spiteful mistress. Ya just can't do things ya usta could and the penalty for trying can be steep. :lol:
Resident Tightwad
PostPosted: Tue Sep 22, 2020 11:20 am
I'm probably in the express lane on the super highway to that scenario given all my injuries.
There are no new unread posts for this topic. And another one.. Suzuki DRZ content
95naSTA
21
2582
Mon Jun 08, 2020 10:08 pm
95naSTA View the latest post
There are no new unread posts for this topic. Meet Ernie... (Diesel Content)
3619
Sun Nov 27, 2016 11:25 pm
There are no new unread posts for this topic. I did a thing (warning: Holden content)
haro1225
41
4578
Thu Jan 11, 2018 11:24 pm
Ghosthawk View the latest post
There are no new unread posts for this topic. Lavrale Quattor. Cagiva Elefant 200. Agrale Quattor 2 stroke
CavemanDan
Thu Jan 21, 2021 8:31 pm
CavemanDan View the latest post
cron
