It is currently Mon Dec 04, 2023 9:44 pm
Post new topic Reply to topic  [ 19 posts ]
 Post subject: So...I bought a Honda
PostPosted: Wed Aug 03, 2016 2:01 pm
1984 Honda VF750F Interceptor. Bought it from a friend of mine last week. It has been sitting in the back of his garage for almost 4 years now. But so far it seems like it's in great shape. It's history is fairly well known since his dad bought this new and it later became my friend's during our high school years. He's since moved on to a few other bikes and unfortunately this one got neglected. Well, maybe it's fortunately for me since he let it go for the price he paid 5 years ago to replace the front forks. It needs a few things and a good cleaning.
So far I had to replace the battery, which I already knew was needed going into this. Got some fresh gas in it and got it fired up and running, but the choke has to remain engaged. Any attempt to pull the choke off and it dies. It idles fine while it warms up but once warmed up it doesn't like to idle. I managed to keep it running long enough to ride for about 20 minutes so I could stir up the oil and change it after. Everything seems to work, it rides great, and runs smoothly when you're on the throttle. Off throttle it sounds rough, not misfiring but not smooth. Carbs undoubtedly will need a cleaning so that's the next project. Buddy I bought it from said they're a PITA to remove, we'll see. Hoping to have this thing registered, inspected, ect. and riding in the coming week or two.
PostPosted: Wed Aug 03, 2016 2:16 pm
Year and Trim: Black 2003 Bonneville SLE
when i saw the title i was going to shun you. then i realized it was a bike and was ok with that fact. nice pickup!
2003 pontiac bonneville Sle with kenwood sound system. Upgraded tweeters, door speakers, deck speakers, kenwood sub and amp. Rage r20 18inch rims. Front and rear KYB shocks and struts. GXP Strut tower brace.. She's a work in progress still
PostPosted: Wed Aug 03, 2016 10:31 pm
Online
Looks like fun.
Any day on 2 wheels is a good day.
Getting to the carbs might be a PITA.. as far as working on bikes go. But, for me at least, working on bikes is wayy easier than a car.
Is valve adjustment part of the bikes maintenance schedule?
PostPosted: Thu Aug 04, 2016 9:50 am
Year and Trim: '99 Montana
'92 Trofeo
The carbs will need to be synced, at least one of the throttles is completely closed at idle causing the misfire. This is kinda annoying to do, you need a 4-port vac manometer and a combination of screwdrivers..
I haven't tried this one, but it seems really easy: https://www.youtube.com/watch?v=GaTRyHxvneY
The trick I use is a feeler gauge (piece of paper) to adjust them on the bench so they are close, they need to be barely cracked open just starting to grab the paper but still pass it through. Then afterwards tweak it with the manometer
http://www.v4market.com/ is where I get everything for mine.
PostPosted: Thu Aug 04, 2016 10:44 am
Year and Trim: 2003 SSEi
Agreed. By your description it's almost guaranteed the idle jet(s) are clogged with varnish. Chances are real good the bike was parked with fuel in the float bowls.
You might want to consider replacing the tires if the bike's been sitting that long with the same rubber. Old tires on a car is one thing, on a bike it's a whole 'nuther story. You don't want to be smoking down the interstate on your bike and lose a tire. Your life should be worth more than what a new set of tires will cost you.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Thu Aug 04, 2016 1:07 pm
Looks like a fun time! So many colors.. Haha
"Penelope" - 2003 SLE - 244k Miles
"Sydney" - 2000 Honda S2000 - 98k miles
PostPosted: Thu Aug 04, 2016 1:20 pm
He said he turned the fuel off last time he rode it, but obviously something isn't right. As for the tires he said they were 1 or 2 years old when he parked it. I had looked them over though, no signs of cracks from dry rotting or anything. It was parked in a conditioned garage and moved around occasionally, I'm sure that helped to some degree.
Thanks for the tips & links there Matt!
I believe so. Not something I've looked into specifically yet though.
(imported) 'Murica!
PostPosted: Fri Aug 05, 2016 9:49 am
Even if he ran the float bowls dry, I'm betting the pilot/idle jets are clogged with something...varnish, corrosion, farfel...
Resident Tightwad
PostPosted: Mon Aug 22, 2016 1:01 pm
Finally got around to going through the carbs. One was definitely gunked up with like 1mm thick of a green film in the float bowl. The other 3 seemed fairly clean. Couple jets did have some trash in them and one of the float needles were stuck. Overall it wasn't a bad job. Got the rebuild kit from V4 Market that Matt linked to. The instructions and info included with that kit was almost worth it by itself. Lots of pictures & info on these bikes in general and a couple service manuals in PDF form! Only real issue I had was when I removed the carbs 4 small springs fell out and I had no idea where they had come from. I did figure out two of them for the throttle linkage adjustment, but had to email the guy from V4 Market about the others and he was able to help identify them and where they went. Hardest part of this job was getting the carbs back on the bike. Ended up replacing all the fuel lines and new fuel filter too. Air filter was already a K&N so just cleaned it and reoiled as well.
But wow, I thought it sounded okay before, this made a big difference. Much better and more responsive now. Here's a short clip of it at idle and a little rev... https://youtu.be/WgXYJZ-g-Dc
Time for registration and inspection!
PostPosted: Wed Sep 28, 2016 5:37 pm
She's been officially on the road for a couple weeks but it's basically rained every day except for 2 in the last two weeks. It seemed to be running great but started noticing a lot of backfiring and went back to tweaking the carbs. Having a tough time dialing them in as far as air/fuel mixture thus far. I give it more fuel and it runs a LOT better in high RPMs but then won't want to idle or is sluggish down low. Take fuel away and it idles great and responds quick on the throttle but is noticeably down on power over 2-3k+ RPM. Not having much luck finding the sweet spot in the middle. I'm sure this is the typical battle with carbs but this is my first adventure messing with them. I'll have to look into the manometer method here soon but the '01 is going back to the top of the priority list this weekend.
First legal ride selfie before leaving for work:
...and here's the I-made-it-to-work-and-didn't-die selfie:
And a couple more pics:
Custom plates came in this week too!
I'm surprised they let this one through actually. As it would be seen to imply an illegal activity and not explicitly my name and initial as the rest of the family vehicle plates are. My second choice was NTCPTR, which is the closest I could get to Interceptor that was available.
PostPosted: Wed Sep 28, 2016 9:26 pm
Online
How are you adjusting the fuel? Needle clip position, and idle a/f screw? And what side of the carb is the screw air filter or engine?
Are you sure you float needles are sealing? If they're leaking you'll pull more fuel in down low.
PostPosted: Fri Sep 30, 2016 12:19 am
'92 Trofeo
You might want to do a compression check. If that's good then you're still looking at a carb balance issue.
Don't expect this motor to make power below 3k rpm. That should only be an issue if you're in 1st gear. 4k rpm on these is the same as running a 3800 at 1500rpm.
That being said, ripping the throttle open should result in many torques and smiles. Consider 4k rpm the minimum for cruising.
PostPosted: Thu Oct 06, 2016 12:21 pm
95naSTA wrote:
What side of the carb is the screw air filter or engine?
Using the pilot screws, they're in the middle but seem to favor the air intake side of the carbs, however they have the pointy tips so they control fuel. I think I did get it really close now though. I started the process over and set the screws back to the stock setting with 2-1/2 turns out. I took much tinier steps this time and got it running strong up high and still idles. Still have a little backfire from the rear cylinders occasionally but it's not as bad as before and it's running better so I can live with that. My friend (the previous owner) said he managed to high-center the bike on a tall curb at some point and bent the rear header so there's a bit of a choke point, that may play a part in it?
In other news Matt, V4 Market that you linked to before has closed http://www.v4market.com/ :sad:
But looks like we can still contact the individual vendors for parts...
PostPosted: Mon Jan 02, 2017 4:18 pm
Little update with the bike. Had to combat an electrical gremlin causing the bike to lose power at random. Looked like there was some previous electrical work that was poorly done. So I ended up cutting the whole pigtail off on that section and redoing it and solved the cutting out. And the starter button was sticking, but I got a box of miscellaneous parts and happened to have another set of controls in it so I swapped those on. Next is the engine temp sensor quit working.
But back in October I took the Interceptor to a car show hosted by a local Continental Tire factory. Unexpectedly won 2nd place in the motorcycle category, so that was super cool on my first outting with it, haha.
Pretty cool trophy too:
Anyhow been riding it whenever the weather was nice enough. Been caught at night a few times and the stock sealed beam headlight was pretty dismal. High beam was good, but the low beam didn't reveal much on the road. I had been looking at some options for a while and debating on ditching the windscreen/fairing and going with a round headlight setup. Which is what I was 100% sure I was going to do when I bought the bike but I started to like how it looks as-is. Then I came across this JW Speaker LED Headlight on Retrofit Source. Initially I assumed the price was for a pair and contacted them to see if they'd split up a set, because motorcycle. They said yeah, it happens often enough that it wouldn't be a problem, just cut the price in half. But I think whoever replied thought I was talking about a different headlight because I later discovered the price was just for one. I wasn't ready to justify that much for one headlight, but I went ahead and got it on a TRS sale the other week. And holy cow what an improvement!
Looks kind of funky but I'm digging it
Lows
Highs
Lows
Highs
And out on the road, Lows
Highs
PostPosted: Tue Jan 03, 2017 8:16 pm
'92 Trofeo
Nice, is there a write-up on that headlamp somewhere? I need that.
PostPosted: Wed Jan 04, 2017 10:42 am
Year and Trim: 01 SLE
Just as bad if not worse. Why is it ok to buy a jap bike but not a car? Seems rather hypocritical.
To each their own tho I guess.
Sorta like fat women...fun to ride but wouldn't want your friends to see ya.
Enjoy your ride.
01 Bonneville SLE
PostPosted: Wed Jan 04, 2017 2:29 pm
Not much found in the way of any detailed write-ups, just a few posts on Jeep forums or generic youtube reviews/comparisons. Only complaints I found from anyone were for winter drivers. These LED lights don't build up any heat at all so if it's snowing, it'll build up on the lens instead of melting off. However on the bike I don't plan to be out in any inclement weather so that shouldn't be an issue.
PostPosted: Fri Jan 20, 2017 11:04 am
:lol: Anyone who would ride one of these things in weather that would cause a buildup of snow to accumulate on the headlight deserves whatever fate the gods have in store for them. I think melting the snow off the headlight might be the least of worries. Why would a crotch-rocket even be pulled out of the garage in that kind of weather? #-o
Resident Tightwad
PostPosted: Fri Jan 20, 2017 12:15 pm
Online
If you haven't already, rain-x your visor.
I put a new visor on not too long ago and forgot to do it.. I got stuck in the rain Tuesday and visibility suckkkked.
There are no new unread posts for this topic. 2005 honda crv
smokingfireball
Tue Oct 04, 2011 9:11 pm
smokingfireball View the latest post
There are no new unread posts for this topic. Vegas Drive in the Honda
rrounds
Fri Mar 16, 2012 7:17 pm
yonkerse View the latest post
There are no new unread posts for this topic. my 1993 honda accord ex
hmmthatguy
Thu May 20, 2010 11:26 am
Jrs3800 View the latest post
There are no new unread posts for this topic. 2000 Honda S2000
6412
Thu Aug 31, 2023 8:11 am
95naSTA View the latest post
There are no new unread posts for this topic. Honda Civic smoking and burning oil.
Oldman
Wed May 18, 2011 11:54 am
repinS View the latest post
