So I rolled the dice today. Kinda won but ultimately lost.
Last weekend I ditched my stock air box for a pod filter and I played around with the slow/fast jets. I ended up with a 175 main and a stock slow jet. The plug looked good after ripping on it for a while so I went with that.
Fast forward to this weekend. 35 miles into NJ there's a vintage mx swap meet with a dirt track open to the public on Saturday. My buddy and I decided to ride there.. the closest bridge into NJ has a speed limit of 35, which was convenient. But most of the roads are 45/50 mph with people going 60+.
My petcock was leaking pretty bad and the replacement didn't get here before this weekend.. add to that my reserve doesn't work. So the bike starts up no problem but it leaked out a gallon of gas over the past week and it died not too long after starting it up outside my house. The owner of our support vehicle, 88' 4 banger Yota truck with a '79 IT 250 in the bed had a gas can. So that got me to the nearest gas station. I fill up and we're on our way.
My bike felt 100% solid cruising at 50-55 mph. My buddy's DT250 kept bogging out every so often on prolonged stints @50+. I think his float is set wrong..
3/4 of the way there his bike was getting progressively worse, so it got loaded up into the Yota truck. I figured out that my leaky fuel issue was a combo between my petcock and the hose clamps on my fuel line. After tightening up the hose clamps it stopped dripping/pissing fuel more or less. At this point I also realize the bolt holding the rear swing arm for the rear drum is missing and the arm is dangling.. lol. It must have rattled it's self loose. I strapped it back up with one of the zip ties holding my kill switch wires.
We get there and my bike had no major problems.
The dirt tack at the meet was built for older mx bikes, which is a good thing, but I've never really ridden anything like this.. it was pretty wild. My tires are kinda beat, hp is pretty low, suspension is meh, and my right ankle/heel isn't the best from my injury back in june.. But I went for it.
2 laps around the track and I was whooped.. I pull off and look down to see my carb pissing fuel out of both vents... tapping it to un-stick the float doesn't help. Taking it apart and moving the float around doesn't help.. I know it's set right.. And my zip tie didn't last - to be expected. Another guy comes over after seeing me screw around with my carb to ask me what's going on. I tell him and he suggests taking a piece of scotchbrite pad to the float needle seat. After doing that, flushing it with gas, and reassembling it seemed to do the trick. Then 10 mins later the bowl vent started to leak again.. lol. Since it was a swap meet I was able to find a nut and bolt for my drum at least. Free of charge.
I was able to make probably 10 or so passes on the track with the leaky bowl vent. 2 at a time. I would just shut the fuel off every time I stopped.
Huuuge learning curve but it was absolutely supplemented by 15+ years riding bmx. It's hard to explain but my impulse reaction got me half way there and figuring it out got me the rest of the way. By no means was I killing it but I wouldn't have been able to make it around the track without my background.
We were getting close to leaving and my buddy points out that my pod filter is gone.. I take a look at my plug and it doesn't look bad at all. I go searching for my filter but can't find it.. I figured since I up-jetted and my plug looked ok, I would try to ride it home.
Wellll here's where I rolled the dice and lost. I only got about 8 miles before I started to loose power and the bike ultimately died.. I fried the piston pretty good.. Turns out I wasn't up-jetted enough to run no filter.. Up into the Yota I went. Live an learn.
The top end is already off.. All the 6 bolts it took. Even though the piston is fried the jug doesn't look too bad. It'll just take a hone, piston/rings and it'll be back on the road. Somewhere in the sub $150 range to fix.. If I keep it stock..
Info on dropping a 92-99:
Here.
