It is currently Tue Feb 19, 2019 11:46 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
 Post subject: Re: The new truck
PostPosted: Mon Sep 05, 2011 12:27 pm
They have the 89. Better gas mileage and I don't need it. It is very rare that we all end up doing things together. Besides, with the ext cab, we will all fit if needed.
PostPosted: Mon Sep 05, 2011 4:53 pm
vogie01 wrote:
2wd=Great mileage and no transfer case to deal with. Prob the easiest vehicle you will ever own.
The better mileage is pretty much going to come from the lighter weight. The amount of friction in a transfer case/front axle when in 2HI on a 4WD vehicle is less than 1%, especially when cruising.
Should be a good truck Matt, but IMO if you're going to have a nice trailer you don't want your truck to look like you drove it off the construction site that afternoon, lol. Tint and changing to a nicer looking grille surround would improve the looks a lot for not too much $$$.
My suggestions for now are to put synthetic fluid in the trans and rear end, flush the coolant and check everything else out. With 88k the plugs should be good for a while yet, but a MAF/TB cleaning, new air filter and checking all the fluids is gonna be cheap insurance. Does it have an OE or aftermarket hitch?
Also, mirrors. Those are going to suck with any kind of trailer behind you, believe me, I've been pulling trailers with these trucks since I've been driving, and the 06+ towing mirrors blow those mirrors out of the water.
$170 + shipping on eBay: http://cgi.ebay.com/ebaymotors/CHEVY-99 ... 1e66aa8ce6
PostPosted: Mon Sep 05, 2011 5:34 pm
Every time I open this thread there are more pictures than the last time I looked at it. Dang photobucket.
Looks like a stock tow package to me. Is that a trailer break setup I spy in the middle, lower part of the dash?
I know it will get better mileage due to weight, but not having 4wd is a wonderful hassle to not have to deal with.
Looks really clean and nice though. Must of been babied by the previous owners. It looks just like the job site trucks that the foreman gets at my Dad's work, but they are beat to hell though. They use the box of the pickup to lay pipe on them, and hall across the site. Not sure why they would beat on them like that. :dontknow:
PostPosted: Mon Sep 05, 2011 8:35 pm
Nice truck Matt. :banana:
I can see you pulling a nice trailer next year and parking it at the KOA as a home base.....then following me back to Canada for a West Coast tour. :bwoohoo:
PostPosted: Tue Sep 06, 2011 12:54 am
Thanks for the replies.
We just got back from a trip to the coast and back. I relly like how it handles the hills, definately has a lot more power than the burb.
You never know Paul, we might end up across the border someday. :btruestory:
PostPosted: Tue Sep 06, 2011 8:11 am
Matt I am quite sure that thing has a locking rear or an LSD...
as well I agree 100% that you need to go to a synthetic gear oil for the rear end, its amazing how much cooler the rear end will stay with a good gear oil... You will want that if you are going to tow... A gasket may be required for the rear diff cover...
I also agree on some good ATF for that trans to keep it happy.. Also did the HD's come with a Trans cooler?
PostPosted: Tue Sep 06, 2011 9:03 am
Senior Moderator
Senior Moderator
Year and Trim: 00' SSEi
If that truck has an LSD, stick with a 80w90 dyno juice and a bottle or two of friction modifier. LSD clutches last longer that way. More than likely it does have an LSD, probably a GM14 bolt 10.5" crown gear.
That will pull and pull and pull.
Good move...
Strange seeing a truck so de-optioned...but I guess...its to serve a purpose.
2016 GMC Sierra 1500 All Terrain. 5.3L 8speed
2000 Bonneville SSEi.
PostPosted: Tue Sep 06, 2011 9:04 am
Senior Moderator
Senior Moderator
Edit, does it atleast have A/C?
PostPosted: Tue Sep 06, 2011 9:20 am
Matt, if it's got a locker it's got the G80 electronic locker. Most of the synthetic fluids now have the LSD stuff in them. The axle should be an AAM 9.5" for the 6.0L 2WD.
EDIT: Matt in the engine pic you can see the drier for the A/C and the lines into the firewall. A/C was pretty much a standard option across all lines.
PostPosted: Tue Sep 06, 2011 10:13 am
Senior Moderator
Senior Moderator
It could be the 9.5 E locker. 10.5 is a more common option, however, and that diff had an automatic locker, the G80 governor style. (Terrible deisgn).
I can tell you that in 80% of our rebuilds, we run 80w90 and friction modifier (Ford Racing, for its smell). The other 20% would be newer Fords. Most new Fords now require 75W140FLS oil, horrible expensive, but required for the Crown/Pinion set. Most new vehicle manufacturers run a 75W90 synthetic oil with modifier. For me to buy that oil, in the bottle or even in a 20 Litre bucket doesn't make sense. We buy the 205 Litre drum of Synthetic 75W90, and a 205 Litre drum of 80w90. I replace to drums of 80w90 to one drum of 75w90.
3.41/Litre X4 plus $7.00 for friction modifier....makes pretty good sense to most of our customers that put 50,000-100,000 kilometers on a year.
Personally, I wouldn't run a synthetic gear lube in a LSD. Been there, done that, repaired that...not cheap.
Back on Topic now please.
PostPosted: Tue Sep 06, 2011 10:38 am
To answer some questions, it does have AC, that was a must have.
It does have the G80 LSD rear. It has a trans cooler, oil cooler and power steering fluid cooler with the hydro boost brakes.
Great info here, keep it coming guys.
PostPosted: Tue Sep 06, 2011 12:26 pm
Senior Moderator
Senior Moderator
I like the black grill and such. Its a truck, thats all, it has a purpose, and it will serve its purpose.
PostPosted: Tue Sep 06, 2011 2:11 pm
50,000 miles with Amsoil in our 05 Duramax (All lubes) and no issues, and the other board I'm on has people that have run hundreds of thousands of miles on it in these trucks.
PostPosted: Tue Sep 06, 2011 2:24 pm
Senior Moderator
Senior Moderator
At rougly 20 dollars a litre, people are getting hosed and don't even realize it.
Put it this way, a multi million dollar Gear shop that specializes in Gear box/trans/diff repair, won't stock or sell any of that stuff. Just 80/90 and 75/90. Over 55% of our total sales are over the counter retail sales to DIY customers and other shops. The only places that stock the AMSoil/royal purple/...ect are the lube shops...but then again, they make all there money on changing oil, and we make on the money on the after repairs from these places lol
Run whatever you like, there isn't a difference that to me, makes one oil worth more than an other, especially in a rear differential/transfer case. It holds 4 litres and contains 4 tapered bearings. When done right, the average diff will last 300,000-350,000 kms.
PostPosted: Sun Sep 11, 2011 12:39 am
Year and Trim: Currently searching for a Bonneville...
I always used Amsoil Severe Gear in the rear ends on the last two trucks I've owned. I remember it being closer to $10 a quart, which is comparable to a standard off the shelf synthetic. They have a 75w-110 which is a good compromise viscosity. Not too thick or thin, but thick enough to withstand some abuse from towing, off-roading and the like. My S/C Frontier had a factory LSD, and with the Amsoil there was no need to add any modifier.
Expensive, sure, but over the life of the vehicle it's cheap insurance and piece of mind. You can usually get some more miles out of synthetic vs conventional, plus there may be a very slight improvement in fuel economy.
Inferno Red 2009 Dodge Caliber SRT-4 125k
PostPosted: Sun Sep 11, 2011 12:45 am
http://www.amsoil.com/mygarage/ProductR ... 20PICKUP+U
Thing I love about the Amsoil website is they have all the specs for what it needs, regardless whether you buy from them or not, all laid out for you online.
Provided you run the right weight and spec fluid you shouldn't have problems. No matter what you use, I highly recommend changing all the fluids.
There are no new unread posts for this topic. A few changes to the truck
Wed Apr 14, 2010 8:34 pm
There are no new unread posts for this topic. The New Truck
KevinMcQ4367
Sat Dec 31, 2011 12:40 pm
KevinMcQ4367 View the latest post
There are no new unread posts for this topic. New truck!!
sspolishing
11
1199
Thu Feb 17, 2011 5:09 am
There are no new unread posts for this topic. New truck?
99bonnieSE
Tue Jun 30, 2009 10:04 pm
There are no new unread posts for this topic. A New Truck For Lash!
lash
31
1619
Fri Oct 16, 2009 8:19 am
lash View the latest post
