It is currently Tue Jun 02, 2020 5:13 pm
PostPosted: Mon Jan 10, 2011 1:09 am
I have a friend with a 2002 Silverado K2500 HD with the 6.0L in it and he is having a problem with it stumbling and stalling at times. He came over today and we cleaned the MAF and TB. Since I had Bill's fuel pressure gauge, I thoght I would go ahead and check the fuel pressure.
He had 46psi with key on and engine off. No change when vacuum line was removed from FPR. When started, the FP went to 40psi and slowly dropped to 28psi. It would only come back to 38psi and never get any higher until the motor was turned off.
I told him it sounded like the fuel pump is going out and he is ordering a new one. Does that sound right?
PostPosted: Mon Jan 10, 2011 1:14 am
How old is the fuel filter? Definitely replace that first. It's on the frame, just below the driver's door, and requires one of those special tools to release the clips on the one end.
Our 00 Silverado farm truck is having trouble at idle, it bogs way down and revs up. It's the fuel filter, no one has gotten around to getting it in to have it replaced yet, though. Sounds like a similar issue. On ours the FP and FPR were just replaced.
PostPosted: Mon Jan 10, 2011 1:17 am
Forgot to mention that. We did change the fuel filter, wrenches on both ends, and di not change anything.
PostPosted: Mon Jan 10, 2011 1:21 am
Hm, must be different than what's on our Suburban.
Now that we know that, I concur that it is a weak FP. Your options for replacement are either drop the tank or lift the bed. It's 6 of one and a half-dozen of the other for which way you want to do it. If you have a few strong buddies that will help, I'd definitely take the bed off.
PostPosted: Mon Jan 10, 2011 8:53 am
I agree... That does sound like low fuel pressure...
PostPosted: Sun Jan 23, 2011 1:39 pm
Well, he is on his way over to do the pump swap. Looks like we are dropping the tank. His bed is full of trash he needs to take to the dump.
I will report back later on the progress.
PostPosted: Sun Jan 23, 2011 4:58 pm
Not too bad. I personally think dropping the tank was a lot easier than it would be to pull the bed. With living in a salt free state, it makes it a lot easier to drop the straps.
3 hrs and off he drove.
There are no new unread posts for this topic. How to relieve fuel pressure on 2004 Montana?
Ken_W
Sun Sep 19, 2010 10:04 pm
There are no new unread posts for this topic. 2004 Silverado
itsnitro
Sun Nov 16, 2008 10:58 am
itsnitro View the latest post
There are no new unread posts for this topic. Out with the F150 in with the Silverado
Whitecrystal1
24
3160
Sat Mar 15, 2014 10:05 pm
Whitecrystal1 View the latest post
There are no new unread posts for this topic. 1996 Silverado 4x4
2928
Sat Dec 11, 2010 1:41 am
dangrus4060 View the latest post
There are no new unread posts for this topic. my 1991 silverado
swampthing
12
1897
Thu Jan 29, 2009 5:49 pm
Users browsing this forum: No registered users and 22 guests
