It is currently Sat May 25, 2019 10:15 pm
PostPosted: Wed May 13, 2009 12:10 pm
Year and Trim: 2006 Chevy Silverado LT
1989 Camaro RS LT1
The Truck: Chevy 1500 2WD Single Cab/Long Bed
The Issue: Either the leaf springs or the rear shocks are causing a nasty squeak every time I press down on the rear, shift weight (like when hitting the brakes after reversing), or hit a speed bump/railroad track. I have cleaned out the leaf's and sprayed them with lithium grease, checked the rubber bump stops, and looked at the bushings on the frame connectors for the leaf springs. I cant really tell if anything is wrong there. I did notice that part of the shocks had vertical scratches on them, but I dont know if that is abnormal. Does anybody have any suggestions that I could check out? GMPD has Delco shocks for 65.99 shipped, but if thats the issue, these only got 39,XXX miles. Any thoughts?
--2006 Silverado LT-3/3 RCX Lift, Bilstien 5100's, CAI, Exhuast, BFG A/T's,
Tuners Inc. dynotune, Aeroforce Interceptor, Kicker 10" TC, iSimple Interface
--1989 Camaro RS-LT1/700r4 drivetrain swap, Corvette trans internals w/2200 stall,
rebuilt engine with LT4 cam
PostPosted: Wed May 13, 2009 12:15 pm
Year and Trim: 2000 ssei
check the driveline, make sure it's not the drive shaft moving around or the tailshaft housing on the tranny bouncing. my 91 has a problem that makes a knock that sounds like it could be anything, and it is caused by the two bolts that hold the tailshaft housing to the crossmember backing out and allowing for drivline movement it took me forever to find it.
I don't know what the 4l65-e's case looks like to know if something similar could be the culprit
i really thought I had a piece of suspension bumping somewhere until i found this
2000 ssei white debadged, autozone solid front mount, NGK tr55 plugs, Napa Beldin wires, MSD Coils, drilled slotted rotors, monroe max air rear shocks, 18" KMC Hot wheels redline w/ 235/50/18 bfg G-force tires, pioneer DEH-P580mp deck, Infinity Ref 6.5s and 5.25s, Kappa 6x9's on crossfire amp, kappa 12 on kenwood amp, and cleared headlights.
Gumball wrote:
my pockets dont sag and are still kinda tight.
PostPosted: Wed May 13, 2009 6:19 pm
Year and Trim: 95 sle
check to see its not a exhaust hanger/clamp / muffler hanger
my truck makes the same sound when hitting bumps.
i havent fixed it yet.
tuffguyracing.com
83 regal 468 big block chevy
02 gmc k2500 6'' lift kit 35'' tall tires 148,000 miles original drive train
95 bonneville sle stock 230,000 miles original engine one trans rebuilt
95 bonneville ssei 163,123 miles rebuilt engine (mean green bonne) sold
95 chevy suburban k1500 203,000 miles wifes truck sold
01 ford f350 crew cab long bed 7.3l diesel 160,000
PostPosted: Wed May 13, 2009 7:42 pm
1989 Camaro RS LT1
I know it is not the exhuast. I am pretty sure I can rule the shocks out after more investigation today.
PostPosted: Tue Jun 02, 2009 12:51 am
1989 Camaro RS LT1
The cause of the noise was the "clips" that go over the outer 2 leafs. When the leaf flexed, they were grinding/vibrating (sounds dirty...). I sprayed the crap out of the clips (all 4, even though I think only 2 were doing it). The noise and vibration went away instantly when I sprayed them, so hopefully it will stay that way for a while. If not, I may need some advice on what to put on them.
PostPosted: Tue Jun 02, 2009 12:59 am
Year and Trim: ____
something heavier. motor oil, having a high film strength, is a good thing to drip over those types of things. won't wear out as quick as something in a can
guess i should track down the squeak in my RF suspension....yeah...maybe.
John
PostPosted: Tue Jun 02, 2009 1:01 am
1989 Camaro RS LT1
I doubt it will make that much of a difference, but the stuff I used was a "dry" lube, that was in a rattle can. It leaves a little bit of white residue where you overspray/coat stuff.
PostPosted: Tue Jun 02, 2009 1:05 am
Year and Trim: ____
Yessir. Got the same stuff in my truck's left storage box. Comes in handy lots.
John
There are no new unread posts for this topic. 04 Grand Am rear wheel bearing or suspension problems
J Wikoff
Sun Jun 05, 2011 4:48 pm
Archon View the latest post
There are no new unread posts for this topic. problems with 96 Silverado
3797
Tue Feb 23, 2010 5:57 pm
LakevilleSSEi View the latest post
There are no new unread posts for this topic. 2008 Silverado
Mek 97SSE
Thu Jan 28, 2010 11:42 pm
Sadden View the latest post
There are no new unread posts for this topic. 2003 Silverado
Sirius
Tue May 20, 2014 2:42 pm
Sirius View the latest post
There are no new unread posts for this topic. 2004 Silverado
itsnitro
Sun Nov 16, 2008 10:58 am
itsnitro View the latest post
