USB
RJGill84
- Year and Trim: 2001 Pontiac Bonneville SE
Re: USB
Unlikely, as the stock stereo would need a way to decode the digital signal coming from the USB cable, and it does not have this capability.
If you're trying to hook up an MP3 player, there are ways to do this without USB.
"SLE without the ugly" - leather, climate control, sound, 3.05 gearing, 180* t-stat, tints. http://www.gillsystems.com
- TenGHz
- Posts like a Northstar
- Year and Trim: 2005 GXP
Re: USB
Cheapest and easiest method to hook up an MP3 player to your stock deck would be the use of an FM modulator. This is what I used for a good long time till I finally got myself a new deck that has a USB port.
-Joshua-
- harofreak00
Re: USB
Adding an input, possible
Adding USB... very un-possible
petraman
- Year and Trim: .
2013 Audi A4 6MT - Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Re: USB
So wait, you want to be able to control your Mp3 player with the stock deck, or do you just want to charge it with USB? There's absolutely no way to control it with your stock deck, but if you want to just charge it through USB, I think there is a way... I can't get onto Crutchfield from work, though, so I can't check it out...
petraman
- Year and Trim: .
Re: USB
Again, I can't get to Crutchfield from work, so what does the link go to?
lewis26
- Posts like an L27
- Year and Trim: 2003 SLE || 51k miles
Re: USB
Seems like a whole hell of a lot of money to spend for just USB input. What exactly are you trying to connect to your stereo?
-Mike
blackout
- Year and Trim: 96 Bonneville SE
Re: USB
you can buy an adapter from crutchfield for the steering wheel controls if you want to use and aftermarket H/U depending on which one it is.
96 SE Pioneer AVHP5700 head unit(ipod connection) new are intake, clear corners, new foglights. HID head lights (Soon to have new rims) as soon as it gets warm enough.
