Roof water leak
leloncio
Year and Trim: SSE 1998
Roof water leak
Post by leloncio »
Hi,
Has anyone found water leaks in the corner of the roof of the car, my sse 98 has a sunroof, when it rains water enters the driver's corner, but I don't know if the leak is from the sunroof or some seal
95naSTA
Re: Roof water leak
Post by 95naSTA »
The sunroof drain tubes likely pulled away from the inlets on the metal sunroof tray or the tubes are failing. You'll have to remove the A B and C pillar trims then grab handles to look above the headliner and see.
leloncio
Re: Roof water leak
Post by leloncio »
Thanks.
Im going to try....
J Wikoff
Re: Roof water leak
Post by J Wikoff »
Careful with those grab handles. The retention clips are kinda fragile with age.
