Help i need somebody's help
frankdux420
Year and Trim: 1997 se
Post by frankdux420 »
Help please my 97 Car has been trying to go dead in drive and reverse when in drive or reverse rpms are under 1 battery gauge drops car tries to die put in park it idles back to normal and battery gauge goes back to normal when on the highway you can see the battery trying to die i have replaced alternator - water pump - serpentine belt - battery Thanks
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Re: Help i need somebody's help
Post by MKMike »
Many things can do this.
It could be electrical or it could be something else, like worn out spark plugs, a broken vacuum hose, clogged fuel filter, failing fuel pump or even just a tank of bad gas.
You originally posted on a good thread for something to check---the ground buses beneath the carpets.
When these develop corrosion--and it happens on many Bonnevilles--- all sorts of troubles can occur because electric parts that don't have a good ground aren't going to work well, if at all.
Another common area of corrosion is on the ends of the battery cables, underneath the plastic covering.
Once you remove the bolt, the covers should slide off rather easily.
Are you losing any coolant?
Usually noticed first in the coolant reserve tank but remove the radiator cap when the engine is cool just to be sure it's full.
The 3800 engines develop intake gasket leaks and plenum (plastic upper intake) leaks which must be addressed quickly to prevent engine damage.
It's a problem with the original plastic intake gaskets and original plastic plenum.
Have you had the car checked for codes?
Are there any codes or is the Service Engine light on?
If the car has not been "tuned up" in recent memory, that can be a very good place to start.
Rockauto.com has very good prices and gives forum members a discount.
Look at their post in the Pontiac Bonneville Club Vendor's Forum for the code.
A tune up means replacing the spark plugs (preferably ACDelco or NGK plugs), fuel filter, PCV valve and air filter.
If it has been a long time since they were replaced, it can be a good idea to also replace the spark plug wires.
You can remove and inspect the spark plugs for wear or fouling.
There's no way to visually inspect the fuel filter.
The PCV valve should rattle when shaken.
The air filter should be clean.
You could also have a vacuum leak from cracked vacuum hoses or a stuck PCV valve.
All the rubber vacuum hoses get brittle and crack over the time--often where you can't see.
Murphy
Year and Trim: 1999 Pontiac Bonneville SSEi
Post by Murphy »
Something like this happened to me a few weeks back, turned out I need a new Ignition Control Module. Replaced it and the stalling stopped! Very easy and simple to replace!
1995 SLE - First Car, 275k running/looking strong
1999 SSEi - New bae, Sleeper wannabe with 218k and growing. TEPs Stage 3. Engine work soon.
1oldman
Post by 1oldman »
any diagnostic codes? that could help a lot. - BC
