Type II Delco swap question
SuperHbody
Year and Trim: 1988 LE
Post by SuperHbody »
So I was looking into doing this to my 88' and wondered if I had to switch up to that style ignition wires or keep my existing ones.
Re: Type II Delco swap question
I see no reason why you couldn't as long as they're in good shape and reach everywhere correctly.
SuperHbody
That's what I thought. I didn't know if the wires were rated differently between the two styles' of ignition coils.
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Post by MattStrike »
The newer 7mm wires won't fit the 8mm wire guides anyway.
Zeik75
Post by Zeik75 »
You can use the wires, I just wrapped the excess around the bottom of the coils and across to keep it from hanging.
MattStrike wrote:The newer 7mm wires won't fit the 8mm wire guides anyway.
mine did, but the LN3 has some fancy clip ones that actually close over the wire.
-Austin-
1oldman
Post by 1oldman »
Make sure you have the bracket for the newer type II ICM. The type II ICM won't mount onto the type I ICM bracket. I found out the hard way. If you have all the parts (bracket, ICM, 3 coil packs, and di-electric grease - IIRC the plug wire length from the type I works fine with the type II) you'll be done in about 15 minutes. - BC
SuperHbody
Sweet, thanks for the help guys! Got it all set up. Is there a real difference in performance or is it just more reliable?
1oldman
Post by 1oldman »
I can't really tell in performance, but the car does seem to run a bit smoother and significantly more reliable, just my personal observation. - BC
EDIT:
HERE IT IS! THE THREAD I'VE BEEN LOOKING FOR!!!
http://www.pontiacbonnevilleclub.com/fo ... tml?hilit=' ' ICM Bracket ' '
