GM07b harness - Does it work with 2000 SSEi (Bose system)?
Junior28
Post by Junior28 »
Did any of you install this with your aftermarket head unit with Bose system? Do all the speakers play correctly? Here's a link to the harness:
http://www.amazon.com/Scosche-Wiring-Ha ... automotive
Do you miss the chimes? Also is there anything else I would be missing besides the chimes if I go with this harness as opposed to the Metra GMOS-09?
Oh, and if I plan on replacing the Bose amp and trunk deck speakers with my own 4-channel amp and speakers, while adding a mono amp for subwoofers, would this harness be an issue?
bobgto65
2004 Bonneville GXP
Re: GM07b harness - Does it work with 2000 SSEi (Bose system
Post by bobgto65 »
As long as you don't care about the chimes, that unit will work whether you keep the Bose or put in a different 4 channel amp. But you have to know the pin layout so you can make the right connections.
bobgto65
Junior28
Post by Junior28 »
Alright, thanks! Do you know where I could find the pin layout?
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
if you run a search using my name you will find it in some of my posts in the audio section
bobgto65
PaulHeinen
Year and Trim: 2000 SSEI
Post by PaulHeinen »
Bob
I can not find that wiring diagram you mentioned
How much messing around will I have to do if I use the harness he mentioned instead of the GMOS-09??
THe onstar hasnt worked since 2008 and I dont care about the chimes but I dont want to have to mess around rewiring a bunch of stuff no matter which harness I buy
Any chance you could walk me thru it or point me to a place with a walk thru??
Thanks
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
Tell me what aftermarket HU model number you have and I'll post the pin conncetions tomorrow.
bobgto65
