1991 LE throttle body coolant tubes
jimbone_sdca
- SE Member
- Year and Trim: 1991 Bonneville LE
Unable to find viable "L" tube Since My L tube Corroded into the throttle body, and the elbow tube which is the intake for the coolant is totally corroded and the hole in the engine block is filled with corrosion and there is practically no coolant flow through....IF I use a sae tap with 20 threads per inch can i use 2 solid brass pipe plugs and locktite to close the holes forever since they are no longer manufactured and you cant find useable ones at the junkyards and auto dismantlers or even on E-BAY. The car won't stall and fail to start like when the coolant temperature sensor went bad and caused the engine to flood and fuel pressure regulator had to be replaced or The MAF sensor went bad, will it?
Zeik75
- Posts like an L36
- Year and Trim: 1988 LE
2000 SSEi - Location: Lincoln, NE
Re: 1991 LE throttle body coolant tubes
I have one in my garage thats good pay shipping and its yours. I might have a spare gasket and o-ring laying around also.
-Austin-
