I had to put the winter tires on my 1987 delta 88 royale, I needed a new air chuck to fill the tires up as mine broke so I went to autozone for one. while at autozone I I could have sworn I picked up a bottle of bar's leaks engine repair that goes in the oil.
I got home. opened oil cap and opened bottle of bar's leaks. turned bottle of bar's leaks upside down into oil filler hole and left it to drain while I swapped the stock tires for the snow tires. finished changing tires and when I pulled out bottle from oil fill hole I noticed it was BAR'S LEAKS AUTOMATIC TRANSMISSION REPAIR :o
soooooooooooo. I left the car right in the spot where it was. did not start it at all. my question is can I just do like 2 oil changes to flush out all that thick ass transmission repair fluid from my engine ?
