motor shaking, smells like rotten eggs, no start., code 13
Posted: Mon Dec 23, 2013 12:35 pm
1987 olds delta 88
yesterday I started my delta 88 to run to auto part store only 10 mins away. as soon as I started it, motor had a pretty bad shake.
let it idle for a few but shake did not go away, drove to auto part store and drove back home. car seemed a lil sluggish but still ran.
let car sit over night, then today my wife went to go to work and she let the car warm up and started to drive, made it about half mile from the house and the car started shaking really bad, then the check engine light came on so she pulled over to call me. I told her to try to start the car and it would not start. it would crank but not start at all. so I scanned the computer and got code 13.
( code 13 - Oxygen sensor voltage stays between 0.35 and 0.55 volts for 30 seconds when the TPS signal was above 0.55 volts. The engine had been running for at least 40 seconds with an engine temperature above 110° F. )
so while I got to my wife where she was stranded, I tried to start the car while stepping on the gas, it would sound like it wanted to start but it would not stay running at all.
so I then un plugged the M.A.F ( don't ask me why ). and with m.a.f unplugged I started the car while stepping on the gas and it turned over and stood running. so while it was running I plugged the M.A.F back in and took foot off the gas and it still stayed running.
so I had my wife drive it home. while she was driving home it started shaking again, and smelling like rotten eggs when she got to the has and was parking..
can anybody please help me with this. I need to try to figure this out today and fix it so my wife can safely return back to work..
my Bonneville that I just changed the transmission on runs great but has a bad axel I need to replace before she can drive it.
HELP PLEASE.. THANK YOU.
