Electronic Levelling Control
89OldsRocket
Year and Trim: 1989 Oldsmobile 88 Royale Brougham Regency - FE3
Post by 89OldsRocket »
My 89 has the "ELC" for auto load leveling with the rear airshocks and control unit on the passenger rear right side. Where is the compressor located for the system?
1989 Oldsmobile 88 Royale Brougham Regency - Grey on Grey - FE3 - X06 Package - Limo Tint - Clarion HU - 2K Pontiac Grand Am 15" Alloy Rims
89OldsRocket
Re: Electronic Levelling Control
Traced the air lines and they seem to go into the floor on the right side either in the trunk or under the right rear passenger seat.
RJolly87
Post by RJolly87 »
I believe it is under the hood, front drivers side. Mounted low, but you should be able to spot it right away. I bet if you took a pic of that corner of the engine bay, we could draw an arrow right to it
89OldsRocket
RJolly87 wrote:I believe it is under the hood, front drivers side. Mounted low, but you should be able to spot it right away. I bet if you took a pic of that corner of the engine bay, we could draw an arrow right to it
Thanks, found and tested it, all is good now that I installed a new airshock.
