Lowering Spring Group Buy!!??
- yourgrandma
- Year and Trim: '02 SSEi
I have a quote for a basic price on a set of custom made lowering springs for our poor neglected platform.
The price should be around $450 for a set, plus shipping.
Im working on deciding springrates and exactly how much of a drop to put in them. So far Im looking at about a 1.5" drop and a 35% increase in springrate over FE5 springs. Progressive rates are possible, but I dont think Im really up for engineering the ramp rate and all that right now.
So, give me your input. Whos interested? Is there another drop value or springrate youd like to see? What color do you want?
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Re: Lowering Spring Group Buy!!??
I'm in for this. I would also be looking at a 1.5" drop.
What were the color options?
- gweg_b
- Posts like a Northstar
- Year and Trim: 95 LeSabre Custom
01 Bonneville SSEi
09 G8 GT - Location: Cambridge, OH
Ok, I'm giddy! I'm in!
The values mentioned are fine for me. And black would be just fine.
- yourgrandma
Yeah, I dont know if they have different color options, I was just asking for general opinions. Im guessing black is it.
I plan to order by the end of the week. I want to get as many people in on this as I can and see if we can get a price break.
- gweg_b
01 Bonneville SSEi
Yeah, just let me know when. I have some money put aside that I was saving for something else, but I can use it for springs.
Just a refresher - we need to get FE5 struts, right? How about the shocks, would be need to replace those, or should FE2 work? I replaced my originals with AC Delco's about 2 years ago, so they are still good, and I don't want to replace them if I don't have too (they weren't cheap
- yourgrandma
I dont think you HAVE to use GXP struts, but it couldnt hurt. They are tough to find, so Im putting together a way to use 97-09 W body struts in front.
- 95naSTA
- Year and Trim: 95 SLE
So, both bottom diameters of the 97-03 W and 00+ H front springs are confirmed to be the same? Or in other words, you're sure the H-body spring will work in a W-body strut spring seat? And also that the seat is the same distance from the strut mounting location?yourgrandma wrote:They are tough to find, so Im putting together a way to use 97-09 W body struts in front.
- WhiteArrow3800
The springs should be the same across the board for the Bonneville. So you could use "FE5" springs in an FE2 strut. It would be beneficial to grab FE5 equipment, but not necessary.gweg_b wrote:Just a refresher - we need to get FE5 struts, right? How about the shocks, would be need to replace those, or should FE2 work? I replaced my originals with AC Delco's about 2 years ago, so they are still good, and I don't want to replace them if I don't have too (they weren't cheap).
- gweg_b
01 Bonneville SSEi
I can understand the struts, but I was really wondering about the shocks. I just didn't know if there was much of difference with the shocks, since they can me level adjusted, and didn't know if FE2 and FE5 shocks had different rates.
- WhiteArrow3800
FE5 rear shocks are a bit stiffer but same with the fronts, I wouldn't see it necessary to source out FE5 rears if your FE2 are new, especially being ACDelcos.
- gweg_b
01 Bonneville SSEi
Thanks, Booze! Yeah, I didn't want to have to buy new rear shocks just yet.
- yourgrandma
The bottom mounting holes will need to be enlarged but otherwise, w body struts appear to be identical.95naSTA wrote:So, both bottom diameters of the 97-03 W and 00+ H front springs are confirmed to be the same? Or in other words, you're sure the H-body spring will work in a W-body strut spring seat? And also that the seat is the same distance from the strut mounting location?yourgrandma wrote:They are tough to find, so Im putting together a way to use 97-09 W body struts in front.
- repinS
- Moderator
- Year and Trim: 09 G8 GT
GXP FE5 struts are $114 a pop from RockAuto. That's how I got mine.yourgrandma wrote:I dont think you HAVE to use GXP struts, but it couldnt hurt. They are tough to find, so Im putting together a way to use 97-09 W body struts in front.
- yourgrandma
Acdelco no longer makes them and they are fresh out. Rock might still have some. Anyway, let's keep this on topic. Who wnts some springs!?
- gweg_b
01 Bonneville SSEi
So, it's looking like just the 3 of us?
- yourgrandma
I haven't heard back about a group buy price. I also just found a place that claims to have 98-99 sts eibach pro kits in stock. I ordered one. I'll post the link if anyone else wants to see if they can still get a set.
- gweg_b
01 Bonneville SSEi
If nothing else, I would like to try for a set if no group buy is going to happen.
2003 SSEi
- Posts like an L67
- Year and Trim: 2003 SSEi.
LOTS of Mods
yourgrandma wrote:I also just found a place that claims to have 98-99 sts eibach pro kits in stock.
- yourgrandma
- gweg_b
01 Bonneville SSEi
So, they actually have those in stock then? Not like another place that had them listed, but once ordered, said they were out. Well, can't hurt to try.
