ecm swaping
allanb
- Year and Trim: 1996 se w/l67
ecm swaping
will an ecm from a 97 se work in a 96 se. i know engine and trans are the same,but thats about it. not shur of any other differences. the purpose of this is to get a zzp tune mainly because of the vs cam i installed
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Re: ecm swaping
The trans is actually different, '96 was still using the 4T60. Everything '97 and up got the 4T65. But as far as the trans sensors/electronics I'm not sure if they're compatible. Hopefully someone else can chime in and get you more details on this. I think as long as ZZP knows what trans you have they should be able to give you what you need...but then again, it's ZZP.
I'd try to talk to them and make sure they know what you have and what you're giving them.
Last edited by WhiteArrow3800 on Mon Jul 30, 2012 2:04 pm, edited 1 time in total.
