2001 bonneville sunroof seal
Ok, called the dealer about getting a new sunroof seal and they said I had to buy the glass with it... REALLY??? Not only can I hear the seal leaking I can see it is beat.... any info? Thanks
Re: 2001 bonneville sunroof seal
I'm not aware of a way to put a new seal on the glass, it's molded in somehow. Junkyard will be your best bet for finding a new one.
Once again you are a wealth of knowledge... Thanks. Found a sunroof for $80 in mint condition - I guess that glass is on quite a few different vehicles. Only other question, the sunroof visor/sunscreen fabric is falling off of it, can it be removed without pulling the entire headliner down? Thanks again...
- sethjamesrimrodt
- Posts like an L36
- Year and Trim: 2004 GXP
This should help you, http://www.pontiacbonnevilleclub.com/fo ... =43&t=9351
Seth
- harofreak00
To remove the sunshade, remove the glass and slide the sunshade forward. Release the 2 front clips, slide forward more, and release the 2 other clips.
