Plog install
Plog install
How easy will it be to install a power log? And is there a noticeable difference in the exhaust tone?
Re: Plog install
sounds about the same to me... now if you have different mufflers it might make a difference. its pretty easy i did mine in about 30 min. i did break my cross over bolts so i bought a new pair of stainless bolts to hold the X-over to the Plog. I would also recommend getting a couple new studs just in case, i had one of my destroy itself on the way out.... used a bolt and broke it in the head... so i wish i would have had a extra stud/nut.
S
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
Re: Plog install
Ok thanks for the info
