Fuel sender fix....
- wdudetocool
- SSEi Member
- Year and Trim: 2000 se
Fuel sender fix....
got the part i learned about in this place to fix the fuel gage........took me an hour and now ......IT WORKS!!!!! THANKS GUYS!!!!
Re: Fuel sender fix....
Good to hear it. Nothing is worse than running out of gas.
- wdudetocool
- SSEi Member
yes ive done that twice....when i first got the car the dash didnt work at all. thank god everythings fixed and comfy!!! ...lol
00Beast wrote:Good to hear it. Nothing is worse than running out of gas.
keir
- SSEi Member
- Year and Trim: 2000 ssei
Good for you.I have had the part for quite a while now but still have yet to take on the project.
Black 91 SSE-Where it all started....
Red 95 Grand Prix SE-Gone but not forgotten....
Grey 00 SSEI -The current daily driver.
Dark Grey 2011 Dodge Charger-The new flagship.
Ken_W
- Posts like an L27
- Year and Trim: 2000 SSEi
@keir - I hear you. I had my part for about six months before finally getting up the motivation to begin. But I was able to get 'er done, even though I had a lot of corrosion on the locking ring in my trunk.
I suggest you watch Hans' video on YouTube for a sense of reassurance about the procedure. This is not a diffficult procedure. Since it involves a fuel component, you might be a bit intimidated, but there is no need to worry (as long as nobody is smoking around the car). If you have trouble getting your locking ring off, get a big heavy hammer (borrow or buy). Once that ring is off, things go pretty fast. Having a working fuel gauge that you fixed yourself is a very satisfying feeling!
Ken_W
Ken_W
- wdudetocool
- SSEi Member
yes indeed! it actualy was a very simple procedure believe it or not.....
Ken_W wrote:@keir - I hear you. I had my part for about six months before finally getting up the motivation to begin. But I was able to get 'er done, even though I had a lot of corrosion on the locking ring in my trunk.
Ken_W
- wdudetocool
- SSEi Member
i have the same problem, what the name of the part i need?
Ken_W
- Posts like an L27
@iRoll4z:
You can fix this yourself for under $40, assuming you have a basic level of wrenching ability and some basic tools. Here is a link to an excellent video by club member Hans that will tell you almost everything you need to know. If you still have questions after viewing it, feel free to ask them here.
Part One: http://www.youtube.com/watch?v=-7cY_IPCVfI
Part Two: http://www.youtube.com/watch?v=FST1whbc ... re=related
Part Three: http://www.youtube.com/watch?v=9N16YmV9 ... re=related
There is also a written tutorial here in our TechInfo section, as well as several threads written by club members as they went through the procedure. Use the Search feature to find the threads.
Ken_W
Ken_W
- Bugsi
- Year and Trim: (RIP 10/31/15) 1997 SE
05 Mercedes S500 4Matic - Location: Sunnyvale, CA
I did the one on the wife's `01 Grand Prix, same part, same procedure. I watched Hans' video first, then just got to work and got it done. It was pretty easy, actually. Give yourself maybe 2 hours and have plenty of paper shop towels and rubber gloves on hand.
`05 Mercedes S500
`05 Mercedes S500
- Ghosthawk
- Posts like an L27
- Year and Trim: 2004 SLE
since my car had over 100k on it I decided to go ahead and swap in an entire fuel pump module. Thanks to the board for the Rock Auto discount code, but unfortunately the gauge is still wacky even after the new module. It isnt as erratic as it was before but still pegs itself against the speedo rim when full and sounds the chime for low fuel before it ever reaches one quarter tank level.
2004 Bonneville SLE "Bonnie the Ghosthawk" or the 4dr Firebird...Gone but not forgotten
The Blog, http://www.tobthebat.wordpress.com
Luna LeMans on Smashwords
https://www.smashwords.com/books/view/870754
Luna LeMans in Amazon paperback
https://www.amazon.com/dp/1983273589
- wdudetocool
- SSEi Member
sounds to me like the little metal prongs that sweep across the piece that measures fuel level arent making good contact.
Ghosthawk wrote:since my car had over 100k on it I decided to go ahead and swap in an entire fuel pump module. Thanks to the board for the Rock Auto discount code, but unfortunately the gauge is still wacky even after the new module. It isnt as erratic as it was before but still pegs itself against the speedo rim when full and sounds the chime for low fuel before it ever reaches one quarter tank level.
