1997 bonne se
Posted: Sat Aug 13, 2011 7:29 pm
by glenn304bonne97
So i just had the driver side front wheel bearing hub replaced on my car. After it was done i was driving it home and the it started making that rumbling noise again when i turn the steering wheel to the right at speed over 15 mph. Should i take the new wheel hub off and or could the other side be bad too.
Re: 1997 bonne se
Posted: Sun Aug 14, 2011 10:36 pm
by pappyl
Always good to change both at same time. Other will go soon.
Jack up the right side, put in neutral (leave tire on), put hand on strut spring and turn the wheel a bunch. Should NOT feel any vibration radiated to the spring, if you do most likely the bearing...
