1997 bonne se
glenn304bonne97
- Year and Trim: 1997 bonneville se
1997 bonne se
So i just had the driver side front wheel bearing hub replaced on my car. After it was done i was driving it home and the it started making that rumbling noise again when i turn the steering wheel to the right at speed over 15 mph. Should i take the new wheel hub off and or could the other side be bad too.
[img][/img]
pappyl
- Year and Trim: 1995 Pontiac Bonneville SSEi
Re: 1997 bonne se
Always good to change both at same time. Other will go soon.
Jack up the right side, put in neutral (leave tire on), put hand on strut spring and turn the wheel a bunch. Should NOT feel any vibration radiated to the spring, if you do most likely the bearing...
