Cruise Control Issue.
38kronik00
Post by 38kronik00 »
On my 02 SSei this only happens occasionally but ill be driving normal highway speeds and the cruise will shut itself off i then set it back at speed and after a few seconds it quits again. It does this about 4 or 5 times and then it stays and doesn't do it again for a week or so. Any clues?
2002 Bonneville SSEi 4+ years ownership 103xxx miles.
SD Headers self coated with ceramic header spray, Highflow CAT, Magnaflow muffler in place of resonator, Super 44 Mufflers, Solid Front Mount, Autolite 104's, Rear Spring Assists, Transgo Shift Kit, Intense PCM. My car is NHL certified :P
Archon
Re: Cruise Control Issue.
Post by Archon »
A couple of common things that can cause that is too much slip in the torque converter, and a faulty throttle position sensor. Service engine soon light lit?
golfyeti
Every available option
Post by golfyeti »
FWIW, for a while my cruise control would disengage whe I used the left turn signal. Problem eventually went away.
Mark
The Familyman's Trans-Am
Intense 3.4 MPS, Intense FWI, Intense PCM, copper NGKs TR55's, MSD wires, MSD coils, BWD ICM, MagnaFlow High Flow Cat, drilled 180 'stat, solid front mount, Monroe Max Air rear shocks, Moog rear mounts, Moog suspension bushings, cleared front corners, 190,000 miles
