Can you put a wider tire on your bonne gxp ?
bigrod64
Year and Trim: 2004 PONTIAC BONNEVILLE GXP
Post by bigrod64 »
hey, can any one tell me if i can put a wider tire like a 245/50zr18 on my 04 gxp? it already has the 235/50zr18.Just wanted to know if anybody else is running a wider tire on their gxp.
Re: Can you put a wider tire on your bonne gxp ?
It will fit with a small possibility of a slight rubbing at full lock but your speedometer will be off 1.4%, which means your speedometer will read around 59 at 60 MPH. Not a huge difference, but you should be conscious of it. It also means your odometer and mileage if you track it will be of a little bit too.
From PM:
bigrod64 wrote:Subject: Can you put a wider tire on your bonne gxp ?
hey thanks for the input ,but what do you think about me running the 245 in the back and the 235 on the front?
00Beast wrote:That would be a poor decision. You'd want your wider tires up front where your drive tires are, and lose all options of rotating tires. Go the same size all around, whatever you do.
Lets keep this in here bud. :beerchug:
