SSE Cluster in a 94 SE?
Blue_Bonne
Year and Trim: 1994 SE
Post by Blue_Bonne »
Could a 94 sse cluster fit and work correctly in a 94 se bonneville
J Wikoff
Re: SSE Cluster in a 94 SE?
Post by J Wikoff »
There might be some wiring changes. Most of it would probably work fine. However, I don't know how the DIC will react to the lack of bulb moniter wiring. I think it would constantly tell you all the bulbs are out, and the hood is open, and maybe the doors... There's probably a way around it by wiring some grounded leads into the harness.
Blue_Bonne
o ok and i jus thought about the gears aren't on it either plus i have a 94 se with the shifter on the column... it may not work
Blue_Bonne
