Resetting check engine light
Blue_Bonne
Year and Trim: 1994 SE
Post by Blue_Bonne »
I had a code which was to change the coolant temp sensor... and thats been changed. How do i get rid of the engine light?
Re: Resetting check engine light
Disconnect the battery and touch the terminals together for 10 seconds and then leave it disconnected for a half hour or so. Otherwise it should clear after a set number of key cycles.
Blue_Bonne
what do you mean by touch the terminals together
Touch the cables together, excuse me. Got about 10 things going on right now, sorry.
comatoast
Post by comatoast »
Blue_Bonne wrote:I had a code which was to change the coolant temp sensor... and thats been changed. How do i get rid of the engine light?
Noone local with a obd2 scanner? They can delete it in about 30 seconds.. Just had a "converter flow" code deleted today.. Whatever the F that is
Current mods - FWI, Intense 1.0 PCM, 3.4"- 3.5", Intense MPS, AL 104s, 180 Stat , Intense/TG shiftkit, Aeroforce Interceptor scan gauge
Upcoming mods- 1.9 rockers, 105#springs, Headers, 103s, 3.3, tune..
Blue_Bonne
but i had them scan it with the obd2 bout it keep sayin error or was it just that scanner... i have a 94 so...
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
OBD 2 is for anything 1996 and up. I believe the 94 is still OBD 1. It may be OBD 1.5, which is the old style codes with the new style plug.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
I believe 94 is OBD 1.5. You'll need an OBD 1 scanner with an OBD II cord, in essence. Any shop with a snap-on scanner should be able to do it. AZ won't...
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
What code did you get? Just curious.
If you touch the cables together(while disconected) it pulls any possibly stored voltage in the car.
comatoast
Post by comatoast »
Sorry, forgot it was a 94.. But still He had to have the right connections to see the code anyways.. Weird that he Couldnt/didnt delete it ..
And what code was it?
