FM modulator- do I need anything else?
dakotapalm
- SSE Member
- Year and Trim: 1994 Pontiac Bonneville SSEi
http://www.amazon.com/Scosche-FM-MOD02- ... B001QBG614
I'm looking to buy this from Amazon- I have the stock radio/CD player that is in the SSEi. Will I need anything else, or should I be able to just plug this in and go?
Thanks. Again, this board is amazing; I've learned A LOT.
1994 Pontiac Bonneville SSEi; CAI; Hood vents; SE grille; LED mirror turn signals; LED running lights (wired to fogs);
Garage:1999 Nissan Maxima SE, stock; 2003 Chevrolet Suburban LS, K&N filtercharger;
sonoma_zr2
- Retired Gearhead
- Year and Trim: 1999 SSEi
Re: FM modulator- do I need anything else?
that is all you need. I have a similar product from a different manufacturer. this one is nicer than mine in that it has a nice remote on-off switch with input.
dakotapalm
- SSE Member
Great! I went ahead and placed the order. Reviews on Amazon seemed pretty good.
kristie_jeff
- Year and Trim: 05 Bonneville SE
IDK about your particular car, but for my 2005 SE, I had to get 2 antenna adapters, one that connects to the back of the radio, and on that will connect to the antenna lead. They are not standard sizes on this one.
lewis26
- Posts like an L27
- Year and Trim: 2003 SLE || 51k miles
That is because the antenna connection is in a different place under the dashboard cover in 00+ There is a simple connection inside the dash somewhere.
-Mike
- John Deere Boy
- Retired Moderator
- Year and Trim: 1993 SSE
Member since Nov 2003 - Location: Centerville, IN
If you end up not being happy with the fm modulator, here is another option if you're savvy with electronics.
http://www.pontiacbonnevilleclub.com/fo ... 13&t=10585
dakotapalm
- SSE Member
I've read that, and I like the idea, but would this word for my CD player unit? Actually, to complicate matters, it won't read CD's correctly- an "E R R" message comes up; but I don't actually listen to CD's much so that isn't a problem itself, but I'm not sure if the "jumpers and pins" could be converted for the CD player.
- John Deere Boy
- Retired Moderator
Yep, the mod is pretty much the same for tape decks or CD players (i've done it to both), but you do need a working CD player unit for the mod to work, because the radio has to think it's playing a CD when it's actually playing your mp3's. If you still want to do the mod, you can usually pick up a tape deck on ebay for $15.
- John Deere Boy
- Retired Moderator
If your CD player still tries to spin CD's before the err message pops up, you might be able to fix it simply by wiping the laser eye with a q-tip and rubbing alcohol. That trick fixed mine and my brother's s10 cd player.
Last edited by John Deere Boy on Fri Mar 26, 2010 6:04 pm, edited 1 time in total.
dakotapalm
- SSE Member
Thanks- and Go Boilers!
dakotapalm
- SSE Member
Well, what a great day off work! I got to play some basketball, and when I got home I saw that my FM modulator had arrived from Amazon. They even included the male-to-male wire that connects the mp3 player to the input--I didn't expect that!
I got everything wired up. Power coming in off the dash mounted cig lighter and everything works like a charm. It's even set on a station where i do receive a fairly strong signal (88.3, never listen to it) but without any song playing, it is pure silence. With a song playing, it's very good sound, although I admit I'm no audiophile.
I really recommend this, folks. 27 dollars that were well-spent.
- John Deere Boy
- Retired Moderator
Good to hear!
