Weird smell coming out of the 97
94SilverSSEi
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Post by 94SilverSSEi »
There is a weird smell coming out of the 97 and after you smell it for a while with all the windows shut it starts to make you sick
I know it is NOT:
Burning Oil
or any kind of gas fumes
Does really smell like coolant either cuz its not real strong like coolant but it kinda makes you sick-might be exhuast
I really have no clue what it could be
Also this only happens when the heat is on-If the ac is on or nothing is on the smell is not there
Cars runs really good no noises or anything recently change valve cover gaskets like 2 months ago
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
wake
Re: Weird smell coming out of the 97
Post by wake »
quick question..hows it running? how black is the inside of the exhaust pipe..and does the exhaust leak any water/oil?
wjcollier07
Year and Trim: ____
Post by wjcollier07 »
Smell like eggs does it?
John
94SilverSSEi
68 w/400
94 SSEi
No not like eggs. Its not really nasty smelling its just bad it kinda makes u sick after a while that why i was wondering if it could be exhuast or something
idk about the echaust it seems to run normal and doesnt blow anything weird
Clay
wake
Post by wake »
hows the antifreeze? please tell me its green not red :wink:
and is your oil milky?
i could be wrong here but if you say you only smell it when the heat or ac is on..that makes me personally think coolant problems..hows the passenger side carpet? dry i hope
sonoma_zr2
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
Post by sonoma_zr2 »
sounds like your heater core burst a leak. passenger floor should be wet.
94SilverSSEi
68 w/400
94 SSEi
I recently took out the whole interior. And both passenger and driver floor were wet but I suspected coffee or something as it looked like there had been as explosion of coffe throughout the car. Don't know. The coolant might have went down a tad but nothing noticeable. If it was the heater core wouldn't I not get heat? Cuz my heat blows really hot.
How could I check to see if it is coolant problems or heater core?
It does have red. But the uim was put on in 06 but there has been 90+k put on the car since then. :twisted:
Clay
RJolly87
Post by RJolly87 »
Have you done the intake gaskets yet? I smelled what smelled like coolant that was burning before a friend of mine's cut loose.
reb
Year and Trim: 1997 Bonneville SE 40th Ann Edition
Original Owner
Post by reb »
Any film residue building up on the interior side of the windshield glass?
94SilverSSEi
68 w/400
94 SSEi
No film residue on windshield. Haven't changed intake gaskets but they go about 90-100k on them. But it's was all highways and and put on. In 3 years.
Clay
Bugsi
05 Mercedes S500 4Matic
Post by Bugsi »
I'd bet money on heater core leak.
`05 Mercedes S500
94SilverSSEi
68 w/400
94 SSEi
Also the coolant does go down a very tiny bit. It takes about 2 weeks to get about 1/4 below the cold mark.
I didnt notice it at first but after checking after a couple weeks realized it was losing a tiny bit every once in a while
Also how would I check and see if it is the heater core for sure?
Clay
bobfather99
Year and Trim: 1995 White Bonneville SE
Post by bobfather99 »
Coolant pressure tester might work in this situation.
One more thing to check is the little weep hole for the A/C system. My mom and dad had a Malibu that leaked from the little fitting, it dripped condensation onto the carpet.
Hate for you to tear out the heater core when its something like that!!
188340 Miles as of 06/07/10, still running.........
LIM/UIM Work done 4/23/07 at 145000 miles...
94SilverSSEi
68 w/400
94 SSEi
Where is this weep hole located?
Clay
I doubt it'd smell, though. The A/C just drips water that condenses on the condensor. I'd also clean your EVAP as shown in Techinfo.
Ol' Timer
Year and Trim: 1991 Olds 88
Location: New Jersey - Most of Our Elected Officials Have Not Been Indicted
Post by Ol' Timer »
bobfather99 wrote: One more thing to check is the little weep hole for the A/C system. My mom and dad had a Malibu that leaked from the little fitting, it dripped condensation onto the carpet.
That weep hole was/is the a/c evaporator drain tube connection. It was probably disconnected and the water drained onto the floor/carpet.
Bugsi wrote:I'd bet money on heater core leak.
x2
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels
2002 Snap Orange Beetle - Auto - Turbo
1991 Dark Garnet Red Oldsmobile 88 - Donated to Science
bobfather99
The a/c evaporator should drip near the back of the firewall on the drivers side. You should see the end of a tube sticking out of the firewall lower to the ground.
If this leaks, the water would smell a little funky if it allows to stand for while. Just something to check before you tear into the heater core.
94SilverSSEi
68 w/400
94 SSEi
Update
within about 2-3 weeks my coolant level has went down about 1 inch although it has been mighty cold the last couple days.
Any thoughts?
I'm started to get worried that my gaskets are taking a crap but I want to eliminate everything else first.
Clay
Coolant leak + smell = Heater Core. Check your passenger side floor again, I bet it's wet.
rogers9c1
Year and Trim: 1999 buick park ave 1996 chevy caprice 9c1
Post by rogers9c1 »
how are your rear wheel well's? mine were rusted out thus letting water under the rear seat giving off a mold like sent, just some thing for you to check. good luck
