Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
If you ask me, I'd guess it doesn't sound that good for actually listening to music. Maybe he's going for SPL... but if that's the case, he better spend as much on Dynomat as he did on speakers.
Every time the (4) 15" subs hit they are going to distort the crap out of the sound coming from the drivers mounted in the rear deck.
~Adam
'99 SSEi
'02 Volvo S60 AWD 2.4T
'02 Jeep Liberty Sport
'89 Chaparral 187XL w/ 4.3L I/O Mercruiser
'00 Cannondale Jekyll 900SX
Follow me on twitter: adumb
mntnbkr wrote:If you ask me, I'd guess it doesn't sound that good for actually listening to music. Maybe he's going for SPL... but if that's the case, he better spend as much on Dynomat as he did on speakers.
no they wont distort the drivers on the rear deck.. the drivers on the rear deck have the baskets of them covered in black electrical tape to stop any air pressure from the subs from getting under the cones of my midrange speakers.
i thought about that ahead of time..
and as for the air pressure going into the car the enclosures are ported thru the back seat and the whole armrest setup was removed to allow the air to exit the trunk while the back seat is on.. but at comp the back seat will be off..
I would have to assume it's SPL with a setup like that. SQ guys usually build with a bit more attention paid to aiming the speakers, and not so much attention to the number of speakers. I could be way wrong though.
~Adam
'99 SSEi
01bonneSC wrote:Guess its just not for me. I listen to punk/ska and have no need for that, just gimme a tight 10" sub and some new replacement speakers and im set.
then you gotta hear some metalica drum and bass solo's or some greenday or nirvana. maybe even some of my pink floyd
you would love the way it sounds... ever been to a rock concert or a mosh pit.. sounds just as loud..
That's the first time I've seen a Bonne with no trunk! Very much overkill IMO. Twin 12's with 5000 clean watts is more than enough bump. I remember Taylor's (Chicago) ride a few years ago, he could bounce coins three inches high off his roof! He even blew the pass thru door right off.
Quad 15's should blow the trunk lid off.
