Rough at idle & low speed
RegencyRoyale
Year and Trim: 1995 Oldsmobile Eighty Eight Royale LS
Post by RegencyRoyale »
The past week I've noticed sometimes on start up the car runs rough, shakes a little, like a "put put put" sound. On pick-up it does it too, but around 40-50mph it stops and runs as normal. There are no warning lights or anything glowing. I do know there is a hole in the muffler that has been getting worse and makes some of the noice and vibration but I don't know if it would really cause this sorta issue or not...Not much to go on but just thought I'd ask if anyone had any thoughts...
1fatcat
Year and Trim: before cars
Re: Rough at idle & low speed
Post by 1fatcat »
plugs, wires, fuel pressure regulator, fuel & air filters? When was the last tune up and what was done?
RegencyRoyale
I have no idea. The original engine failed last year and so a used one went in. Came with no maintenance records. I just know it's from a cared for car. Since that time there hasn't been much use, maybe a few hundred miles. 106,000 miles on the engine.
Last edited by RegencyRoyale on Fri Jun 12, 2009 2:00 am, edited 3 times in total.
