How to clean up yellow lenses???
RegencyRoyale
Year and Trim: 1995 Oldsmobile Eighty Eight Royale LS
Post by RegencyRoyale »
Anyone know anything that will clean up the yellow-ish color film that sometimes builds up on plastic lenses? My corner lamps are pretty nasty looking. The headlights are crystal clear but the corners look frosted and dirty-yellow. Any advice? Read about WD-40 or AJAX doing it but I'm not sure...
Last edited by RegencyRoyale on Tue May 05, 2009 2:06 am, edited 3 times in total.
bill buttermore
Re: How to clean up yellow lenses???
Post by bill buttermore »
There are products specifically made for restoring clear plastic lenses and they work great. They all use the same principle - remove the layer of yellow oxidation, and polish the underlying clear plastic. Sometimes a fast-cut rubbing compound is enough to do it, other times, the surface coating must be removed by sanding, and then restored with progressively finer grits of polish.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
ChilinMichael
Year and Trim: 2004 Volvo S60
Post by ChilinMichael »
Meguiar's has a product called Plast-X, now it actually comes in a box I saw at wal-mart called "Meguiar's Headlight restoration kit" has a neat tool to hook to your drill to polish the plast-x in with. That would be a good recommendation for you.
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
You can DIY that kit for $10 by getting the Plast-X, then getting a cloth polishing wheel at Harbor Freight.
The best way for plastic is to wet-sand the plastic with 1000, 1500, and 2000 grit sandpaper, then hit it with the Plast-X on the cloth wheel.
If you go that route, you will have to re-apply the Plast-X every few months to keep the lenses clear. I've used the above method with great success on several cars now. It's been about a year since I've done my LeSabre, and it just needs the occasional touch-up. The lenses I did for my fiancee look good, too, after a year and less touch-up.
RegencyRoyale
I've never used Plast-X, I'll check it out. Thanks
